New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Phil_Kay
Functional Data Explorer Workshop with Chris Gotwalt, JMP Chief Data Scientist
"Have you run DOEs or built models in JMP? You all have? Then you are ready for this...""Have you run DOEs or built models in JMP? You all have? Then you are ready for this..."Selected JMP users joined Chris Gotwalt, JMP Chief Data Scientist, for a special hands-on workshop on Functional Data Explorer in JMP Pro. Chris has kindly agreed to making all the materials available for anyone to use. You can find them attached.
Let me know ( @Phil_Kay ) if you need anything else to help you understand how functional data analysis can help you to solve your complex science and engineering challenges.
Last Modified: Feb 14, 2024 10:06 AM
Comments
