gail_massari
Mixture DOE - Slides and Case Studies
These three files mixture DEO files are from  @tom_donnelly
Mixture DOE Webcast.pdf:  This slide presentation covers a 5-mixture DOE (2 constraints and response data), a 10-factor mixture DOE (6 mixture, 2 continuous, 1 categorical and 1 block), and a 7-component mixture DOE (with 5 and 7 constraints).  It summarizes real-world design issues addressed by the JMP custom DOE platform, shows how to read ternary plots, and describes and gives uses for 1st order (main effects), 2nd order (quadratic effects), and 3rd order (Scheffé Special Cubic) models.
JMP Complex multi-factor custom design.pdf and JMP-7mixconstraints.pdf describe the case studies used in the demos.
Ron Snee's 2017 PharmaTech article Speeding Up Formulation Development: QbD principles and strategic thinking can reduce the time requi... includes results from JMP mixture designs.
Comments
Dear Gail,
Where can I find the JMP files that were used in the webcast?
Article Tags
Contributors
