PowerPoint accompanying JMP webcast. See accompanying resources and videos made from Olivia Lippincott's webcast:
http://www.jmp.com/en_us/events/ondemand/mastering-jmp/using-geographic-maps.html
.shp files are located:
- On Windows C:\Program Files\SAS\JMP\version_number\Samples\Import Data
- On Mac: /Library/Application Support/JMP/version_number/Samples/Import Data
Note: for JMP PRO, use directory name JMPPRO.
If you cannot see the file, you might need to change the file type to All Files.
If you saved custom map files when using a previous version of JMP, for example JMP 12, you should move the files to:
- On Windows C:\Program Files\SAS\JMP\13\Maps
- On Mac: /Library/Application Support/JMP/13/Maps
You may also be interested in the JMP US ZIP Code Maps and the Add-Ins for Geocoding Place Names and Custom Map Creator
Also see the documentation on mapping in JMP.
