Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUtilizzo%20di%20JMP%20per%20sfruttare%20tutta%20la%20potenza%20di%20SAS%C2%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CIFRAME%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F1872491364001%2Fdefault_default%2Findex.html%3FvideoId%3D4899961435001%22%20width%3D%22300%22%20height%3D%22150%22%20allowfullscreen%3D%22%22%20webkitallowfullscreen%3D%22webkitallowfullscreen%22%20class%3D%22video%20floatRight%22%20mozallowfullscreen%3D%22mozallowfullscreen%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%0A%3CP%3EScopri%20come%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EAccedi%2C%20interroga%20e%20sottoponi%20a%20sottoinsiemi%20i%20dati%20SAS%20direttamente%20da%20JMP%20o%20da%20una%20semplice%20interfaccia%20JMP%20creata%20utilizzando%20JMP%20Scripting%20Language%20(JSL)%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EUtilizzare%20l'esplorazione%20visiva%20JMP%20per%20scoprire%20incongruenze%20nei%20dati%20e%20problemi%20di%20codifica%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ERiassumere%20i%20dati%20su%20una%20mappa%20utilizzando%20Graph%20Buildr%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EDeterminare%20i%20fattori%20correlati%20agli%20arrivi%20tardivi%20utilizzando%20la%20modellazione%20Partition%20e%20Bootstrap%20Forest%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ECrea%20codice%20di%20lavoro%20SAS%2C%20invia%20il%20lavoro%20SAS%20direttamente%20da%20JMP%20a%20SAS%20e%20visualizza%20l'output%20SAS%20nel%20registro%20JMP%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EComprendere%20la%20logica%20dell'utilizzo%20di%20queste%20tecniche%20e%20altre%20opzioni%20per%20l'utilizzo%20sinergico%20di%20JMP%20e%20SAS%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccesso%20ai%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Using JMP to Harness the Full Power of SAS®
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
See how to:
  • Access, query and subset SAS data directly from JMP or from a simple JMP interface created using JMP Scripting Language (JSL)
  • Use JMP visual exploration to uncover data inconsistencies and coding issues
  • Summarize data on a map using Graph Buildr
  • Determine factors related to late arrivals using Partition and Bootstrap Forest modeling
  • Create SAS job code, submit SAS job directly from JMP to SAS and view SAS output in JMP log
  • Understand the rationale for using these techniques and other options for using JMP and SAS synergistically
Start:
Thu, Oct 8, 2020 02:00 PM EDT
End:
Thu, Oct 8, 2020 03:00 PM EDT
Labels (1)
0 Comments
