Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EC%C3%B3mo%20utilizar%20JMP%20para%20aprovechar%20todo%20el%20potencial%20de%20SAS%C2%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CIFRAME%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F1872491364001%2Fdefault_default%2Findex.html%3FvideoId%3D4899961435001%22%20width%3D%22300%22%20height%3D%22150%22%20allowfullscreen%3D%22%22%20webkitallowfullscreen%3D%22webkitallowfullscreen%22%20class%3D%22video%20floatRight%22%20mozallowfullscreen%3D%22mozallowfullscreen%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%0A%3CP%3EVea%20c%C3%B3mo%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EAcceda%2C%20consulte%20y%20cree%20subconjuntos%20de%20datos%20SAS%20directamente%20desde%20JMP%20o%20desde%20una%20interfaz%20JMP%20simple%20creada%20con%20lenguaje%20de%20script%20JMP%20(JSL)%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EUtilice%20la%20exploraci%C3%B3n%20visual%20de%20JMP%20para%20descubrir%20inconsistencias%20de%20datos%20y%20problemas%20de%20codificaci%C3%B3n%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EResumir%20datos%20en%20un%20mapa%20usando%20Graph%20Buildr%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EDeterminar%20los%20factores%20relacionados%20con%20las%20llegadas%20tard%C3%ADas%20mediante%20el%20modelado%20de%20particiones%20y%20Bootstrap%20Forest%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ECree%20un%20c%C3%B3digo%20de%20trabajo%20SAS%2C%20env%C3%ADe%20el%20trabajo%20SAS%20directamente%20desde%20JMP%20a%20SAS%20y%20vea%20la%20salida%20de%20SAS%20en%20el%20registro%20de%20JMP%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EComprender%20la%20raz%C3%B3n%20fundamental%20para%20utilizar%20estas%20t%C3%A9cnicas%20y%20otras%20opciones%20para%20utilizar%20JMP%20y%20SAS%20de%20forma%20sin%C3%A9rgica.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAcceso%20a%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Using JMP to Harness the Full Power of SAS®
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
See how to:
  • Access, query and subset SAS data directly from JMP or from a simple JMP interface created using JMP Scripting Language (JSL)
  • Use JMP visual exploration to uncover data inconsistencies and coding issues
  • Summarize data on a map using Graph Buildr
  • Determine factors related to late arrivals using Partition and Bootstrap Forest modeling
  • Create SAS job code, submit SAS job directly from JMP to SAS and view SAS output in JMP log
  • Understand the rationale for using these techniques and other options for using JMP and SAS synergistically
Start:
Thu, Oct 8, 2020 02:00 PM EDT
End:
Thu, Oct 8, 2020 03:00 PM EDT
Labels (1)
0 Comments
