Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMit%20JMP%20die%20volle%20Leistung%20von%20SAS%C2%AE%20nutzen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CIFRAME%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F1872491364001%2Fdefault_default%2Findex.html%3FvideoId%3D4899961435001%22%20width%3D%22300%22%20height%3D%22150%22%20allowfullscreen%3D%22%22%20webkitallowfullscreen%3D%22webkitallowfullscreen%22%20class%3D%22video%20floatRight%22%20mozallowfullscreen%3D%22mozallowfullscreen%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%0A%3CP%3EErfahren%20Sie%2C%20wie%20Sie%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EGreifen%20Sie%20direkt%20aus%20JMP%20oder%20einer%20einfachen%2C%20mit%20JMP%20Scripting%20Language%20(JSL)%20erstellten%20JMP-Schnittstelle%20auf%20SAS-Daten%20zu%2C%20fragen%20Sie%20diese%20ab%20und%20erstellen%20Sie%20Teilmengen%20davon.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EVerwenden%20Sie%20die%20visuelle%20Exploration%20von%20JMP%2C%20um%20Dateninkonsistenzen%20und%20Kodierungsprobleme%20aufzudecken%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EDaten%20mit%20Graph%20Buildr%20auf%20einer%20Karte%20zusammenfassen%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EBestimmen%20Sie%20Faktoren%2C%20die%20zu%20Versp%C3%A4tungen%20f%C3%BChren%2C%20mithilfe%20der%20Partitions-%20und%20Bootstrap-Forest-Modellierung%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EErstellen%20Sie%20einen%20SAS-Jobcode%2C%20%C3%BCbermitteln%20Sie%20den%20SAS-Job%20direkt%20von%20JMP%20an%20SAS%20und%20zeigen%20Sie%20die%20SAS-Ausgabe%20im%20JMP-Protokoll%20an%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EVerstehen%20Sie%20die%20Gr%C3%BCnde%20f%C3%BCr%20den%20Einsatz%20dieser%20Techniken%20und%20anderer%20Optionen%20f%C3%BCr%20die%20synergetische%20Nutzung%20von%20JMP%20und%20SAS%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EDatenzugriff%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Using JMP to Harness the Full Power of SAS®
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
See how to:
  • Access, query and subset SAS data directly from JMP or from a simple JMP interface created using JMP Scripting Language (JSL)
  • Use JMP visual exploration to uncover data inconsistencies and coding issues
  • Summarize data on a map using Graph Buildr
  • Determine factors related to late arrivals using Partition and Bootstrap Forest modeling
  • Create SAS job code, submit SAS job directly from JMP to SAS and view SAS output in JMP log
  • Understand the rationale for using these techniques and other options for using JMP and SAS synergistically
Start:
Thu, Oct 8, 2020 02:00 PM EDT
End:
Thu, Oct 8, 2020 03:00 PM EDT
Labels (1)
0 Comments
