Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-677396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIntroduzione%20a%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-677396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EQuesta%20sessione%20statunitense%20si%20terr%C3%A0%20in%20inglese%2C%20alle%2013%3A00%20(ora%20orientale%20degli%20Stati%20Uniti).%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EI%20nuovi%20utenti%20JMP%20impareranno%20come%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EEsplora%20facilmente%20JMP%20con%20JMP%20Starter.%3C%2FLI%3E%0A%3CLI%3EImporta%20tutti%20i%20tipi%20di%20file%2C%20inclusi%20i%20set%20di%20dati%20SAS.%3C%2FLI%3E%0A%3CLI%3ECattura%20e%20riproduci%20le%20tue%20analisi%20come%20script%20per%20condividere%20i%20risultati%20con%20i%20colleghi.%3C%2FLI%3E%0A%3CLI%3EAccedi%20alla%20vasta%20gamma%20di%20risorse%20didattiche%20integrate%20in%20JMP%2C%20tra%20cui%20indici%20statistici%2C%20tutorial%2C%20dati%20di%20esempio%2C%20collegamenti%20ai%20menu%20e%20molto%20altro.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fen_us%2Fevents%2Flive-webinars%2Fgetting-started-with-jmp%2Fgetting-started-with-jmp-06oct2023.html%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3ERegistrati%3C%2FA%3E%20per%20partecipare.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-677396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Getting Started with JMP
Published on ‎09-13-2023 10:46 AM by Community Manager Community Manager | Updated on ‎09-13-2023 11:15 AM
This US session is held in English, 1:00 pm US Eastern Time.
 New JMP users will learn how to:
  • Easily navigate JMP using the JMP Starter.
  • Import all types of files, including SAS data sets.
  • Capture and replay your analyses as scripts to share results with co-workers.
  • Access the wealth of instructional resources built into JMP, including statistical indexes, tutorials, sample data, menu shortcuts and more.
 Register to attend.
Start:
Fri, Oct 6, 2023 01:00 PM EDT
End:
Fri, Oct 6, 2023 02:00 PM EDT
0 Comments
