Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Developer Tutorial: Using JMP Pro Generalized Regression to Analyze Designed Experiments
Presented in English
Published on ‎11-07-2024 03:30 PM by Staff | Updated on ‎11-12-2026 03:11 PM
DOE allows multiple input factors to be manipulated, determining their effect on a desired output (response). By manipulating multiple inputs at the same time, DOE can identify important interactions that may be missed when experimenting with one factor at a time.
Generalized Regression used in conjunction with a designed experiment may provide answers to questions such as:
  • What are the key factors in a process? (Explanatory)
  • At what settings would the process deliver acceptable performance? (Predictive)
  • What are the key, main, and interaction effects in the process? (Explanatory)
Variable Selection is used to:
  • Fit a sequence of models (maybe many models)
  • Use some metric to see how well each model fits our data
  • Keep the model that fits best
In this video, see how to:
  • Compare different models
  • Decide on the sequence of models to fit
  • Apply technique to some examples
Q&A is included throughout the video.
Resources
Continue the dialog in the comments below.  Direct any questions to Clay Barker @clay_barker.
Start:
Mon, Nov 8, 2021 02:00 PM EST
End:
Mon, Nov 8, 2021 03:00 PM EST
0 Comments
