Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-809936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECr%C3%A9ation%20d'applications%20personnalis%C3%A9es%20avec%20JMP%C2%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%22%3E%3CDIV%20id%3D%22lia-vid-6265864438001w960h540r620%22%20class%3D%22lia-video-brightcove-player-container%22%3E%3CVIDEO-JS%20data-video-id%3D%226265864438001%22%20data-account%3D%226058004218001%22%20data-player%3D%22default%22%20data-embed%3D%22default%22%20class%3D%22vjs-fluid%22%20controls%3D%22%22%20data-application-id%3D%22%22%20style%3D%22width%3A%20100%25%3B%20height%3A%20100%25%3B%22%3E%3C%2FVIDEO-JS%3E%3C%2FDIV%3E%3CSCRIPT%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F6058004218001%2Fdefault_default%2Findex.min.js%22%3E%3C%2FSCRIPT%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2F6265864438001%22%20target%3D%22_blank%22%3E(voir%20dans%20Mes%20vid%C3%A9os)%3C%2FA%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1423605913%22%20id%3D%22toc-hId-1424282517%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ED%C3%A9couvrez%20comment%20faire%26nbsp%3B%3A%3C%2FFONT%3E%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ECr%C3%A9er%20des%20tableaux%20de%20bord%3C%2FFONT%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ECombiner%20les%20fen%C3%AAtres%20de%20rapport%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3EEnregistrer%20et%20partager%20des%20tableaux%20de%20bord%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3EEnregistrez%20le%20script%20dans%20la%20fen%C3%AAtre%20de%20script%20et%20utilisez-le%20pour%20cr%C3%A9er%20une%20requ%C3%AAte%20%C3%A0%20l'aide%20du%20g%C3%A9n%C3%A9rateur%20de%20requ%C3%AAtes%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3EEnregistrer%20le%20tableau%20de%20bord%20en%20tant%20que%20module%20compl%C3%A9mentaire%20JMP%20et%20installer%20le%20module%20compl%C3%A9mentaire%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ECr%C3%A9ez%20une%20application%20JMP%20(.jmpapp)%20et%20comprenez%20comment%20enregistrer%20les%20scripts%20d'application%20%C3%A0%20l'aide%20du%20r%C3%A9pertoire%20ADDIN_HOME%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ERemarque%26nbsp%3B%3A%20des%20questions%20et%20r%C3%A9ponses%20sont%20diss%C3%A9min%C3%A9es%20tout%20au%20long%20du%20document.%3C%2FFONT%3E%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId--1128551048%22%20id%3D%22toc-hId--1127874444%22%3E%20%3C%2FH4%3E%0A%3CH4%20id%3D%22toc-hId-614259287%22%20id%3D%22toc-hId-614935891%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%224%22%3ERessources%3C%2FFONT%3E%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3E%3CA%20href%3D%22https%3A%2F%2Fsupport.sas.com%2Fedu%2Fschedules.html%3Fid%3D2569%26amp%3Bctry%3DUS%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3EApplications%20instantan%C3%A9es%20avec%20JMP%C2%AE%20Application%20Builder%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E(cours)%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3E%3CA%20href%3D%22https%3A%2F%2Fsupport.sas.com%2Fedu%2Fschedules.html%3Fid%3D7464%26amp%3Bctry%3DUS%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3ED%C3%A9veloppement%20d'applications%20%C3%A0%20l'aide%20du%20langage%20de%20script%20JMP%C2%AE%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E(cours)%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscovery-Summit-2018%2FBuilding-Dashboards-and-Applications-With-JMP-US-2018-408%2Fta-p%2F79948%22%20target%3D%22_blank%22%3ECr%C3%A9ation%20de%20tableaux%20de%20bord%20et%20d'applications%20avec%20JMP%C2%AE%3C%2FA%3E%20(tutoriel%20JMP%20Discovery%20Summit)%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPartage%20et%20communication%20des%20r%C3%A9sultats%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Building Custom Applications using JMP®
Published on ‎11-07-2024 03:28 PM by Community Manager Community Manager | Updated on ‎11-08-2024 07:39 AM
See how to:
  • Create dashboards
    • Combine report windows
    • Save and share dashboards
    • Save script to script window and use it to create a query using Query Builder
  • Save Dashboard as a JMP Add-In and install Add-In
  • Create a JMP Application (.jmpapp) and understand how to save application scripts using the ADDIN_HOME directory
Note: Q&A is interspersed throughout.
Resources
Start:
Tue, Jun 30, 2020 02:00 PM EDT
End:
Tue, Jun 30, 2020 03:00 PM EDT
0 Comments
