Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
%3CLINGO-SUB%20id%3D%22lingo-sub-809966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECreazione%20di%20modelli%20predittivi%20avanzati%20-%20Caso%20di%20studio%20su%20petrolio%20e%20gas%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EQuesto%20studio%20di%20caso%20utilizza%20JMP%20e%20JMP%20Pro%20per%20individuare%20parametri%20geologici%20e%20di%20completamento%20ottimali%20nei%20processi%20upstream%20del%20settore%20petrolifero%20e%20del%20gas%20(identificazione%2C%20estrazione%20e%20produzione%20di%20materie%20prime).%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%22%3E%3CDIV%20id%3D%22lia-vid-6232415486001w480h270r60%22%20class%3D%22lia-video-brightcove-player-container%22%3E%3CVIDEO-JS%20data-video-id%3D%226232415486001%22%20data-account%3D%226058004218001%22%20data-player%3D%22default%22%20data-embed%3D%22default%22%20class%3D%22vjs-fluid%22%20controls%3D%22%22%20data-application-id%3D%22%22%20style%3D%22width%3A%20100%25%3B%20height%3A%20100%25%3B%22%3E%3C%2FVIDEO-JS%3E%3C%2FDIV%3E%3CSCRIPT%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F6058004218001%2Fdefault_default%2Findex.min.js%22%3E%3C%2FSCRIPT%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2F6232415486001%22%20target%3D%22_blank%22%3E(guarda%20in%20I%20miei%20video)%3C%2FA%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EScopri%20come%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EComprendere%20l'obiettivo%20dei%20modelli%3A%20determinare%20il%20punto%20di%20rendimento%20decrescente%20per%20l'utilizzo%20di%20materiale%20solido%20aggiuntivo%20e%20costoso%20(materiale%20di%20sostegno)%20nel%20processo%3C%2FLI%3E%0A%3CLI%3EComprendere%20la%20risposta%20di%20interesse%3A%20quantit%C3%A0%20lorda%20di%20petrolio%20e%20gas%20prodotta%20da%20un%20pozzo%20specifico%20nell'arco%20di%20un%20anno.%3C%2FLI%3E%0A%3CLI%3EComprendere%20i%20fattori%20di%20studio%3CUL%3E%3CLI%3E%20Fattori%20controllati%20(20%20parametri%20di%20completamento%2C%20quantit%C3%A0%20di%20materiale%20di%20sostegno%2C%20profondit%C3%A0%20di%20perforazione%20del%20pozzo%2C%20numero%20di%20stadi%20di%20completamento%2C%20lunghezza%20laterale%20del%20pozzo)%3C%2FLI%3E%3CLI%3E%20Fattori%20pseudo-controllati%20(parametri%20di%20posizione%2C%20contea%2C%20latitudine%2C%20longitudine)%3C%2FLI%3E%3CLI%3E%20Fattori%20incontrollati%20(23%20parametri%20geologici%2C%20facies%2C%20spessore%20del%20serbatoio%2C%20porosit%C3%A0%20e%20permeabilit%C3%A0%2C%20carbonio%20organico%20totale%20(TOC))%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3CLI%3EPreparare%20i%20dati%20per%20l'analisi%3CUL%3E%3CLI%3E%20%3CSPAN%3EGestire%20i%20valori%20mancanti%20utilizzando%20l'imputazione%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3CLI%3EUtilizzare%20lo%20screening%20predittivo%20per%20identificare%20i%20predittori%20significativi%20tra%20tutti%20i%20fattori%3CUL%3E%3CLI%3E%20Classifica%20tutti%20i%20predittori%20utilizzando%20Bootstrap%20Forest%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3CLI%3ECostruisci%20un%20modello%20utilizzando%20Fit%20Model%20per%20sviluppare%20rapidamente%20modelli%20lineari%20semplici%20e%20complessi%20utilizzando%20varie%20tecniche%20di%20adattamento%2C%20parametri%20del%20modello%20e%20impostazioni%20aggiuntive%2C%20inclusi%20effetti%20casuali%3CUL%3E%3CLI%3E%20Costruire%20il%20modello%20dei%20minimi%20quadrati%20standard%20(JMP)%3C%2FLI%3E%3CLI%3E%20Costruire%20un%20modello%20di%20regressione%20graduale%20(JMP)%3C%2FLI%3E%3CLI%3E%20Costruire%20un%20modello%20di%20regressione%20logistica%20(JMP)%3C%2FLI%3E%3CLI%3E%20Utilizzare%20la%20regressione%20generalizzata%20(Pro)%20per%20creare%20set%20di%20testo%2C%20di%20convalida%20e%20di%20addestramento%20e%20quindi%20modellare%20dati%20correlati%20e%20ad%20alta%20dimensionalit%C3%A0%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3CLI%3EUtilizzare%20JMP%20Pro%20per%20adattare%20un%20modello%20di%20ensemble%20mediante%20la%20media%20di%20molti%20alberi%20decisionali%3CUL%3E%3CLI%3E%20Guarda%20come%20ogni%20suddivisione%20considera%20un%20sottoinsieme%20casuale%20dei%20predittori%3C%2FLI%3E%3CLI%3E%20Utilizzare%20Prediction%20Profiler%20per%20identificare%20il%20punto%20di%20rendimenti%20decrescenti%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22specifying.JPG%22%20style%3D%22width%3A%20567px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22specifying.JPG%22%20style%3D%22width%3A%20567px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22specifying.JPG%22%20style%3D%22width%3A%20567px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F30933i08122B6F16B5CDA5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22specifying.JPG%22%20alt%3D%22specifying.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EModellazione%20statistica%20avanzata%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Building Advanced Predictive Models - Oil and Gas Case Study
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
This case study uses JMP and JMP Pro to find optimal geologic and completion parameters in upstream oil and gas processes (identifying, extracting and producing raw materials).
See how to:
  • Understand the goal of the models - to determine point of diminishing return for using additional, expensive solid material (proppant) in the process
  • Understand the  response of interest - gross amount of oil and gas produced from a particular well over one year.
  • Understand the study factors
    • Controlled factors (20 completion parameters, amount of proppant, well perforation depth, # of completion stages, lateral well length)
    • Pseudo-controlled factors (location parameters, county, latitude, longitude)
    • Uncontrolled factors (23 geologic parameters, facies, reservoir thickness, porosity & permeability, (TOC) total organic carbon)
  • Prepare data for analysis
    • Handle missing values using imputation
  • Use Predictor Screening to identify significant predictors out of all factors
    • Rank all predictors using Bootstrap Forest
  • Build model using Fit Model to rapidly develop simple to complex linear models using various fitting techniques, model parameters, and additional settings including random effects
    • Construct Standard Least Squares model (JMP)
    • Construct Stepwise Regression model (JMP)
    • Construct Logistic Regression model (JMP)
    • Use Generalized Regression (Pro)to create text, validation and training sets and then model correlated and high-dimensional data
  • Use JMP Pro to fit an ensemble model by averaging many decision trees
    • See how each split considers a random subset of the predictors
    • Use Prediction Profiler to identify point of diminishing returns
Start:
Tue, Sep 22, 2020 02:00 PM EDT
End:
Tue, Sep 22, 2020 03:00 PM EDT
Labels (1)
0 Comments
