Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Accelerating Innovation Using Bayesian Optimization
Presented in English
Published on 10-10-202510:39 AM by
gail_massari| Updated on 11-04-202512:26 PM
Video using JMP 19 was posted in October 2025.
Bayesian Optimization accelerates industrial R&D and lowers the barrier to entry. It saves time and resources by learning from observed response values while using the project goals to recommend the settings to test next.
See how to use JMP Pro Bayesian optimization tools to go beyond the limitations of traditional DOE, where augmentation is based on previous positioning of experimental points and design space optimality criteria only.
Several case studies show how to:
Start with some data.
Define goal(s).
Obtain model.
Perform a search to find next experimental data point(s).
Generate response for new data, update model, and repeat until satisfied.
