JMP is taking Discovery online, April 16 and 18. Register today and join us for interactive sessions featuring popular presentation topics, networking, and discussions with the experts.
Compute Row Sums of a Matrix
Problem
You have a matrix stored in JSL, and you would like to create a column vector that contains the sums of each row of values in the matrix.
Solution
Use a combination of the V Sum() function and matrix transposes:
M = [1 2 3, 4 5 6, 7 8 9];
V = V Sum( M` )`;
Show( V );
The above script results in the following output in the Log window:
Show( V );
V = [6, 15, 24];
Discussion
See Also
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
