Users and their respective permissions can be managed in the Users section under the Admin tab. Once you open the Users section, all of the users present within the server are listed by their username/email. There are five different edit options available to a JMP Live admin:
A full table of data on users can be generated using a REST API through JSL’s HTTP Request() function.
The attached script (JMP Live Login.jsl) is used to log in the admin. This process requires four pieces of information:
Once logged in, the code below can then be used to generate a table containing data on the users.
// List all users and generate a data table with users
request << reset( Url( webJMPUrl || "/api/v2/users" ), Method( "GET" ), Insecure );
data = request << Send;
dt = JSON To Data Table( data );
An important aspect of being a JMP Live admin is knowing how to manage your users’ reports. As an admin, you have access to all reports that are published publicly to the JMP Live server (e.g., any published report where the “shared to:” option selected is “everyone”). You also have access to all privately published reports (e.g., any published report where the “shared to:” option selected is “only me”) and all reports that are published to groups of which you are a member. You do not have immediate access to reports published within groups to which you are not a member, but these reports can be accessed by going to the Groups section under the Admin tab.
Each report can be managed by selecting the “three dots” button, which allows you four options:
Selecting “Edit” allows you to edit the user report with the following options:
Editor's note: Have you read the other installments in our JMP Live admin tricks series?
