JMP is taking Discovery online, April 16 and 18. Register today and join us for interactive sessions featuring popular presentation topics, networking, and discussions with the experts.
juliagong
Staff (Retired)
How to automate the creation of a JMP Add-In using JSL
JMP add-ins are great additions to JMP core capabilities, and sometimes, you may find yourself needing to automate add-in creation with JSL. I worked with automated add-in creation when building my JMP add-in, the JMP to R Custom Add-In Builder. Here’s a nifty JSL trick for auto-creation of add-ins.
The code in this tutorial is adapted from a wonderful script written by @Justin_Chilton, who built the Custom Add-In Builder.
A JMP add-in (.jmpaddin) is a Zip file (.zip). The three minimum components of a JMP add-in are the addin.def and addin.jmpcust files, as well as the JSL script that will run when the add-in is in use. You may add additional files as you would like—for example, other JSL scripts, JMP tables, PDF or Word documents (commonly used for documentation), and pictures (often used for the add-in thumbnail).
In the following script excerpts, anything customizable is in capital letters (e.g. YOUR_ADDIN_NAME).
First, create the string that is used in the addin.def file. You will need your add-in name and ID. The name is what will be displayed on the add-in menu, and the ID is a unique identifier for the add-in, commonly seen in the format com.companyname.username.addinname.
//create string for addin.def file
addinDefString = "id=com.YOUR_COMPANY.YOUR_ID.YOUR_ADDIN_NAME
name=YOUR ADDIN NAME
supportJmpSE=0";
If you know your add-in is only supported on Windows or Mac, respectively, then you should add a line at the end of this string with either:
"host=Win"
Or
“host=Mac”
Next, create the string for your addin.jmpcust file:
addinjmpcustString = "\[<!-- JMP Add-In Builder created --><jm:menu_and_toolbar_customizations xmlns:jm="http://www.jmp.com/ns/menu" version="3">
  <jm:insert_in_main_menu>
    <jm:insert_in_menu>
      <jm:name>Add-Ins</jm:name>
      <jm:insert_after>
        <jm:name></jm:name>
        <jm:command>
          <jm:name>YOUR ADDIN NAME</jm:name>
          <jm:caption>Your Addin Name</jm:caption>
          <jm:action type="path">$ADDIN_HOME(com.YOUR_COMPANY.YOUR_ID.YOUR_ADDIN_NAME)\YOUR_SCRIPT.jsl</jm:action>
          <jm:icon type="none"></jm:icon>
        </jm:command>
      </jm:insert_after>
    </jm:insert_in_menu>
  </jm:insert_in_main_menu>
</jm:menu_and_toolbar_customizations>]\";
Then, in order to package your JSL script as a file, first load it as a text file:
addinScript = Load Text File("$SOME_PATH\YOUR_ADDIN_NAME.jsl");
Then, write all of your files to a zip archive:
//create a ZipArchive to write files to
za = Open("$DOCUMENTS\YOUR_ADDIN_NAME.jmpaddin", zip);
//write all necessary files to ZipArchive (which can also be binary blobs)
za << write("addin.def", addinDefString);
za << write("addin.jmpcust", addinjmpcustString);
za << write("YOUR_ADDIN_NAME.jsl", addinScript);
Finally, you can navigate to the folder you saved your files to and see your add-in, which can be installed upon double-click.
I also created a more “fill-in-the-blank” version of the script, in case you wanted to automate your add-in creation (if you need to create multiple and have variable names for your add-in name, files, directory, etc.), which is below.
The two variable names used in the script are addinName and dir, which are defined as follows:
addinName: the name of your add-in as a string, with spaces and title capitalization as you’d like it to appear in the add-in menu (e.g. “JMP to R Add-In Builder”)
dir: the directory under which you would like to save your add-in
addinDefStr = "id=com.YOUR_COMPANY.YOUR_ID" || addinName || "\!n name=" || addinName || "\!n supportJmpSE=0";
addinjmpcustStr = "\[<!-- JMP Add-In Builder created --><jm:menu_and_toolbar_customizations xmlns:jm="http://www.jmp.com/ns/menu" version="3">
       <jm:insert_in_menu>
         <jm:insert_after>
              <jm:name></jm:name>
              <jm:command>
                <jm:name>]\" || uppercase(addinName) || "\[</jm:name>
                <jm:caption>]\" || addinName || "\[</jm:caption>
                <jm:action type="path">$ADDIN_HOME(com.jmp.]\" || lowercase(regex(addinName, "\s", "", globalreplace)) || "\[)\]\" || addinName || "\[.jsl</jm:action>
              </jm:command>
         </jm:insert_after>
za = Open(dir || "/" || addinName || ".jmpaddin", zip);
za << write("addin.def", addinDefStr);
za << write("addin.jmpcust", addinjmpcustStr);
za << write(addinName || ".jsl", addinScript);
Hope these scripts can help make your add-in creation projects smoother!
Last Modified: Sep 8, 2017 10:36 AM
Comments
Justin_Chilton
Thanks for putting this together, Julia!
I just wanted to add a few more options you can add to the addin.def file.
  • addinVersion - the version number that appears in the View > Add-Ins... dialog.
  • minJmpVersion - the minimum version of JMP the add-in can be installed.
  • maxJmpVersion - the maximum version of JMP the add-in can be installed.
addinVersion=1.3
minJmpVersion=12
maxJmpVersion=13
And if you're interested in using one of JMP's built-in icons for a menu item in your add-in, check out my Built-In JMP Icons add-in for the icon names and use the format below in the addin.jmpcust file.
<jm:icon type="builtin">JMPProSmall</jm:icon>
vince_faller
Super User (Alumni)
What is supportJmpSE?
Justin_Chilton
@vince_faller, the "SE" in "supportJmpSE" stands for "Student Edition," so you only need this to be set to 1 if you need the add-in to work with JMP Student Edition.
SteveTerry
Level III
We would like to provide an add-in to a vendor, but would like the code associated with it to be kept secret.  The statement above suggests that the code would be viewable.  Is there any way to make an add-in in binary form so it couldn't (easily) be reverse-engineered?
Craige_Hales
You can try edit->encrypt on your script(s). Do some testing and be prepared to rework some JSL. If you only have a small bit of secret code, consider moving it to its own include file and encrypting just that. The rest of the code will run normally.
An encrypted script has a hard time looking at itself; if you use expression manipulation or convert expressions to strings, expect some re-writing. Use show globals(); after your script runs to get an idea of what might leak.
Keep your plain text version somewhere safe!
