%3CLINGO-SUB%20id%3D%22lingo-sub-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Eanalisi%20multivariata%20a%20misure%20ripetute%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3ECosa%20ti%20ha%20ispirato%20a%20richiedere%20questa%20lista%20dei%20desideri%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EAlcuni%20di%20noi%20hanno%20proposto%20soluzioni%20alternative%20a%20questo%20problema%20qui%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fm-p%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fmp%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%3C%2FA%3E%20.%3C%2FP%3E%3CP%3EMi%20chiedo%20se%20questa%20implementazione%20non%20sia%20cos%C3%AC%20scoraggiante%20come%20sembrerebbe.%20Le%20caratteristiche%20della%20piattaforma%20mixed-model%2C%20ovvero%20la%20specificazione%20del%20soggetto%20ripetuto%2C%20potrebbero%20essere%20incorporate%20nella%20piattaforma%20partial%20least%20squares%3F%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuale%20miglioramento%20vorresti%20vedere%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EModellazione%20statistica%20avanzata%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20analisi%20multivariata%20a%20misure%20ripetute%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EQuesto%20%C3%A8%20strano%3A%20ha%20tagliato%20la%20parte%20pi%C3%B9%20importante%20della%20mia%20richiesta.%20T%3CSPAN%3E%20a%20mia%20conoscenza%2C%20le%20opzioni%20multivariate%20in%20Fit%20Model%20non%20possono%20gestire%20un%20progetto%20di%20misure%20ripetute%20(non%20ci%20sarebbero%20problemi%20se%20ci%20fosse%20una%20sola%20Y).%20Se%20inserisco%20%22tempo%22%20nel%20modello%20sotto%20MANOVA%20o%20minimi%20quadrati%20parziali%2C%20ci%C3%B2%20non%20si%20adatta%20alla%20natura%20delle%20misure%20ripetute.%20Mi%20chiedo%20se%20esista%20un%20modo%20per%20specificare%20soggetti%20ripetuti%20per%20tali%20analisi%20multivariate.%20Penso%20che%20questo%20sar%C3%A0%20uno%20strumento%20pi%C3%B9%20comunemente%20usato%20in%20futuro%20poich%C3%A9%20pi%C3%B9%20ricercatori%20adotteranno%20%22approcci%20su%20scala%20Omics%20e%20vorranno%20profilare%20suite%20di%20molecole%20negli%20stessi%20soggetti%20monitorati%20nel%20tempo%22.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20analisi%20multivariata%20a%20misure%20ripetute%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
repeated measures multivariate analysis
A few of us have been pitching work-arounds for this here: https://community.jmp.com/t5/Discussions/multivariate-data-with-a-repeated-measures-design/m-p/63267...
I wonder if this implementation is not as daunting as it would seem. Could features of the mixed-model platform, namely specifying the repeated subject, be incorporated into the partial least squares platform?
Why is this idea important?
2 Comments
abmayfield
Level VI
This is strange: it cut off the most important part of my request. To my knowledge, the multivariate options under Fit Model cannot handle a repeated measures design (would be no problem if there was a single Y). If I put in "time" into the model under MANOVA or partial least squares, that doesn't accommodate the repeated measures nature. I am wondering if there is any way to specify repeated subjects for such multivariate analyses. I think this will be a more commonly used tool in the future as more researchers adopt 'Omics-scale approaches and want to profile suites of molecules in the same subjects tracked over time.
mia_stephens
