%3CLINGO-SUB%20id%3D%22lingo-sub-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Eanalyse%20multivari%C3%A9e%20%C3%A0%20mesures%20r%C3%A9p%C3%A9t%C3%A9es%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EQuelques-uns%20d'entre%20nous%20ont%20propos%C3%A9%20des%20solutions%20de%20contournement%20%C3%A0%20ce%20probl%C3%A8me%20ici%26nbsp%3B%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fm-p%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fmp%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%3C%2FA%3E%20.%3C%2FP%3E%3CP%3EJe%20me%20demande%20si%20cette%20mise%20en%20%C5%93uvre%20n'est%20pas%20aussi%20intimidante%20qu'elle%20le%20para%C3%AEt.%20Les%20fonctionnalit%C3%A9s%20de%20la%20plateforme%20%C3%A0%20mod%C3%A8le%20mixte%2C%20%C3%A0%20savoir%20la%20sp%C3%A9cification%20du%20sujet%20r%C3%A9p%C3%A9t%C3%A9%2C%20pourraient-elles%20%C3%AAtre%20int%C3%A9gr%C3%A9es%20%C3%A0%20la%20plateforme%20des%20moindres%20carr%C3%A9s%20partiels%20%3F%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20am%C3%A9lioration%20souhaiteriez-vous%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EMod%C3%A9lisation%20statistique%20avanc%C3%A9e%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20analyse%20multivari%C3%A9e%20%C3%A0%20mesures%20r%C3%A9p%C3%A9t%C3%A9es%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EC'est%20%C3%A9trange%20%3A%20cela%20a%20coup%C3%A9%20la%20partie%20la%20plus%20importante%20de%20ma%20demande.%20J%3CSPAN%3E%20%C3%80%20ma%20connaissance%2C%20les%20options%20multivari%C3%A9es%20sous%20Fit%20Model%20ne%20peuvent%20pas%20g%C3%A9rer%20une%20conception%20%C3%A0%20mesures%20r%C3%A9p%C3%A9t%C3%A9es%20(ce%20ne%20serait%20pas%20un%20probl%C3%A8me%20s'il%20y%20avait%20un%20seul%20Y).%20Si%20je%20mets%20du%20%22temps%22%20dans%20le%20mod%C3%A8le%20sous%20MANOVA%20ou%20moindres%20carr%C3%A9s%20partiels%2C%20cela%20ne%20tient%20pas%20compte%20de%20la%20nature%20des%20mesures%20r%C3%A9p%C3%A9t%C3%A9es.%20Je%20me%20demande%20s'il%20existe%20un%20moyen%20de%20sp%C3%A9cifier%20des%20sujets%20r%C3%A9p%C3%A9t%C3%A9s%20pour%20de%20telles%20analyses%20multivari%C3%A9es.%20Je%20pense%20que%20ce%20sera%20un%20outil%20plus%20couramment%20utilis%C3%A9%20%C3%A0%20l'avenir%2C%20car%20de%20plus%20en%20plus%20de%20chercheurs%20adoptent%20des%20approches%20%C3%A0%20l'%C3%A9chelle%20des%20omiques%20et%20souhaitent%20profiler%20des%20suites%20de%20mol%C3%A9cules%20chez%20les%20m%C3%AAmes%20sujets%20suivis%20au%20fil%20du%20temps.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EObjet%20%3A%20analyse%20multivari%C3%A9e%20%C3%A0%20mesures%20r%C3%A9p%C3%A9t%C3%A9es%20-%20Statut%20chang%C3%A9%20en%20%3A%20Reconnu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
repeated measures multivariate analysis
A few of us have been pitching work-arounds for this here: https://community.jmp.com/t5/Discussions/multivariate-data-with-a-repeated-measures-design/m-p/63267...
I wonder if this implementation is not as daunting as it would seem. Could features of the mixed-model platform, namely specifying the repeated subject, be incorporated into the partial least squares platform?
Why is this idea important?
2 Comments
abmayfield
Level VI
This is strange: it cut off the most important part of my request. To my knowledge, the multivariate options under Fit Model cannot handle a repeated measures design (would be no problem if there was a single Y). If I put in "time" into the model under MANOVA or partial least squares, that doesn't accommodate the repeated measures nature. I am wondering if there is any way to specify repeated subjects for such multivariate analyses. I think this will be a more commonly used tool in the future as more researchers adopt 'Omics-scale approaches and want to profile suites of molecules in the same subjects tracked over time.
mia_stephens
