%3CLINGO-SUB%20id%3D%22lingo-sub-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EMultivariate%20Analyse%20mit%20wiederholten%20Messungen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20Sie%20zu%20dieser%20Wunschliste%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EEinige%20von%20uns%20haben%20hier%20Workarounds%20hierf%C3%BCr%20vorgeschlagen%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fm-p%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2Fmultivariate-data-with-a-repeated-measures-design%2Fmp%2F632672%3Futm_campaign%3Dcm%26amp%3Bemcs_t%3DS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExIUzMzVVdSU0haTkY3fDYzMjY3MnxTVUJTQ1JJUFRJT05TfGhL%26amp%3Butm_medium%3Dnotification%26amp%3Butm_source%3Dgeneral%3C%2FA%3E%20.%3C%2FP%3E%3CP%3EIch%20frage%20mich%2C%20ob%20diese%20Implementierung%20nicht%20so%20entmutigend%20ist%2C%20wie%20sie%20scheint.%20K%C3%B6nnten%20Funktionen%20der%20Mixed-Model-Plattform%2C%20n%C3%A4mlich%20die%20Angabe%20des%20wiederholten%20Subjekts%2C%20in%20die%20Partial-Least-Squares-Plattform%20integriert%20werden%3F%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20gerne%20sehen%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-632921%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EErweiterte%20statistische%20Modellierung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Multivariate%20Analyse%20mit%20wiederholten%20Messungen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632926%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDas%20ist%20seltsam%3A%20Es%20hat%20den%20wichtigsten%20Teil%20meiner%20Anfrage%20abgeschnitten.%20T%3CSPAN%3E%20Meines%20Wissens%20k%C3%B6nnen%20die%20multivariaten%20Optionen%20unter%20%E2%80%9EModell%20anpassen%E2%80%9C%20nicht%20mit%20einem%20Design%20mit%20wiederholten%20Messungen%20umgehen%20(w%C3%A4re%20kein%20Problem%2C%20wenn%20es%20ein%20einzelnes%20Y%20g%C3%A4be).%20Wenn%20ich%20%E2%80%9EZeit%E2%80%9C%20in%20das%20Modell%20unter%20MANOVA%20oder%20partiellen%20kleinsten%20Quadraten%20einbeziehe%2C%20wird%20das%20der%20Natur%20der%20wiederholten%20Messungen%20nicht%20gerecht.%20Ich%20frage%20mich%2C%20ob%20es%20eine%20M%C3%B6glichkeit%20gibt%2C%20wiederholte%20Probanden%20f%C3%BCr%20solche%20multivariaten%20Analysen%20anzugeben.%20Ich%20denke%2C%20dass%20dies%20in%20Zukunft%20ein%20h%C3%A4ufiger%20genutztes%20Instrument%20sein%20wird%2C%20da%20immer%20mehr%20Forscher%20Omics-Ans%C3%A4tze%20%C3%BCbernehmen%20und%20%C3%BCber%20einen%20l%C3%A4ngeren%20Zeitraum%20hinweg%20Profile%20von%20Molek%C3%BClgruppen%20in%20denselben%20Themenbereichen%20erstellen%20m%C3%B6chten.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Multivariate%20Analyse%20mit%20wiederholten%20Messungen%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Best%C3%A4tigt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-632932%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
repeated measures multivariate analysis
A few of us have been pitching work-arounds for this here: https://community.jmp.com/t5/Discussions/multivariate-data-with-a-repeated-measures-design/m-p/63267...
I wonder if this implementation is not as daunting as it would seem. Could features of the mixed-model platform, namely specifying the repeated subject, be incorporated into the partial least squares platform?
Why is this idea important?
2 Comments
abmayfield
Level VI
This is strange: it cut off the most important part of my request. To my knowledge, the multivariate options under Fit Model cannot handle a repeated measures design (would be no problem if there was a single Y). If I put in "time" into the model under MANOVA or partial least squares, that doesn't accommodate the repeated measures nature. I am wondering if there is any way to specify repeated subjects for such multivariate analyses. I think this will be a more commonly used tool in the future as more researchers adopt 'Omics-scale approaches and want to profile suites of molecules in the same subjects tracked over time.
mia_stephens
