%3CLINGO-SUB%20id%3D%22lingo-sub-636753%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EUtilizzo%20dell'intelligenza%20artificiale%20per%20la%20progettazione%20e%20l'analisi%20degli%20esperimenti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-636753%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECon%20l'aumento%20della%20velocit%C3%A0%20di%20implementazione%20e%20dell'utilit%C3%A0%20degli%20strumenti%20di%20intelligenza%20artificiale%20come%20ChatGPT%2C%20JMP%20potrebbe%20utilizzarli%20come%20parte%20di%20EasyDoE%20e%20altre%20piattaforme%20per%20aiutare%20gli%20utenti%20a%20progettare%20un%20esperimento%20e%20l'analisi%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EUsando%20una%20semplice%20finestra%20di%20chat%20collegata%20all'intelligenza%20artificiale%2C%20potrebbe%20farti%20domande%20sui%20fattori%2C%20i%20vincoli%2C%20ecc.%20e%20questo%20potrebbe%20quindi%20utilizzare%20JMP%20per%20costruire%20il%20progetto%20dell'esperimento.%20Altre%20aziende%20stanno%20adottando%20questo%20approccio%20all%E2%80%99intelligenza%20artificiale.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EL%E2%80%99intelligenza%20artificiale%20sembra%20essere%20il%20futuro%20e%20integrarla%20in%20strumenti%20come%20JMP%20sar%C3%A0%20essenziale%20per%20la%20crescita%20dell%E2%80%99analisi%20dei%20dati%20nel%20(molto%20prossimo)%20futuro.%20Non%20implementarlo%20presto%20potrebbe%20significare%20che%20gli%20utenti%20cercheranno%20altrove%20la%20semplicit%C3%A0%20delle%20interazioni%20con%20l%E2%80%99intelligenza%20artificiale.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-636753%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EModellazione%20statistica%20avanzata%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EProgettazione%20di%20esperimenti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EModellazione%20predittiva%20e%20machine%20learning%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-740929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERi%3A%20Uso%20dell'intelligenza%20artificiale%20per%20la%20progettazione%20e%20l'analisi%20degli%20esperimenti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-740929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEssere%20d'accordo.%20La%20funzionalit%C3%A0%20di%20analisi%20dei%20dati%20di%20OpenAI%20avr%C3%A0%20presto%20questa%20funzionalit%C3%A0.%20Attualmente%20non%20%C3%A8%20abbastanza%20buono%20(intelligente)%20per%20la%20maggior%20parte%20del%20lavoro%20del%20DOE.%20%C3%88%20qui%20che%20JMP%20potrebbe%20specializzarsi%3C%2FP%3E%3C%2FLINGO-BODY%3E
Use of Artificial Intelligence For Design And Analysis Of Experiments
With the increase in speed of deployment and usefulness of AI tools like ChatGPT could JMP use this as part of EasyDoE and other platforms to help users design an experiment as well as the analysis
Using a simple chat window linked to the AI it could ask you questions about the factors, constraints etc and this could then use JMP to build up the design of the experiment. Other companies are taking this approach to AI.
AI seems to be the future and integrating it into tools like JMP will be essential for the growth of data analytics in the (very near) future. Not implementing this soon could mean users look elsewhere for the simplicity of interactions with AI.
1 Comment
datadad2
Level II
Agree. OpenAI's data analysis feature will have this capability soon. Currently it is not good (smart) enough for most DOE work. This is where JMP could specialize
