  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
%3CLINGO-SUB%20id%3D%22lingo-sub-52090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EPreferenza%20intervallo%20di%20tolleranza%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-52090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EGli%20intervalli%20di%20tolleranza%20nella%20piattaforma%20di%20distribuzione%20richiedono%20la%20regolazione%20della%20proporzione%20e%20dei%20livelli%20di%20confidenza%20per%20ciascuna%20risposta%20individualmente.%20Sarebbe%20fantastico%20se%20una%20preferenza%20potesse%20impostare%20la%20confidenza%2C%20la%20proporzione%20e%20un%20lato%2Fdue%20lati%20insieme%20all'opzione%20per%20rimuovere%20la%20richiesta%20di%20input%20durante%20l'esecuzione%20dell'analisi.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-52090%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Tolerance Interval Preference
The tolerance intervals in the distribution platform require you to adjust the proportion and confidence levels for each response individually.  It would be great if a preference could set the confidence, proportion and 1-sided/two-sided along with the option to remove the input prompt when performing the analysis.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
