%3CLINGO-SUB%20id%3D%22lingo-sub-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ETabella%20%26gt%3B%20Aggiorna%20dovrebbe%20avvisare%20quando%20la%20colonna%20avr%C3%A0%20esito%20negativo%20a%20causa%20del%20controllo%20elenco%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EQuando%20si%20aggiorna%20una%20tabella%20di%20destinazione%20che%20include%20colonne%20con%20una%20propriet%C3%A0%20Controllo%20elenco%2C%20l'aggiornamento%20su%20quella%20colonna%20non%20riesce%20in%20modo%20invisibile%20se%20la%20tabella%20di%20origine%20dell'aggiornamento%20contiene%20elementi%20che%20non%20sono%20presenti%20nel%20Controllo%20elenco%20della%20tabella%20di%20destinazione.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3ESono%20d'accordo%20che%20l'aggiornamento%20dovrebbe%20fallire%2C%20ma%20dovrebbe%20fallire%20con%20un%20avviso%20e%20un'opzione%20per%20(a)%20rimuovere%20il%20controllo%20elenco%20prima%20di%20procedere%20o%20(b)%20interrompere%20l'aggiornamento.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ECombinazione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Tabella%26gt%3B%20Aggiorna%20dovrebbe%20avvisare%20quando%20la%20colonna%20fallir%C3%A0%20a%20causa%20del%20controllo%20elenco%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EL'ho%20formulato%20male.%20L'errore%20si%20verifica%20quando%20Update%20()%20viene%20chiamato%20da%20uno%20script%20JSL.%20Non%20ho%20verificato%20se%20il%20comportamento%20%C3%A8%20diverso%20quando%20Tabella%26gt%3B%20Aggiorna%20viene%20chiamato%20dal%20menu.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Table > Update should warn when column will fail due to List Check
When updating a target table that includes columns with a List Check property, the update on that column fails silently if the update source table contains items that are not in the target table's List Check.
I agree that the update should fail, but it should fail with a warning and an option to (a) remove the List Check before proceeding or (b) abort the update.
1 Comment
john_madden
Level VI
I phrased this poorly. The failure occurs when Update() is called from a JSL script. I have not tested whether the behavior is different when Table > Update is called from the menu.
