%3CLINGO-SUB%20id%3D%22lingo-sub-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ETableau%20%26gt%3B%20La%20mise%20%C3%A0%20jour%20doit%20avertir%20lorsque%20la%20colonne%20%C3%A9chouera%20en%20raison%20de%20la%20v%C3%A9rification%20de%20la%20liste%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ELors%20de%20la%20mise%20%C3%A0%20jour%20d'une%20table%20cible%20qui%20inclut%20des%20colonnes%20avec%20une%20propri%C3%A9t%C3%A9%20List%20Check%2C%20la%20mise%20%C3%A0%20jour%20sur%20cette%20colonne%20%C3%A9choue%20silencieusement%20si%20la%20table%20source%20de%20mise%20%C3%A0%20jour%20contient%20des%20%C3%A9l%C3%A9ments%20qui%20ne%20figurent%20pas%20dans%20la%20liste%20Check%20de%20la%20table%20cible.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EJ'accepte%20que%20la%20mise%20%C3%A0%20jour%20devrait%20%C3%A9chouer%2C%20mais%20elle%20devrait%20%C3%A9chouer%20avec%20un%20avertissement%20et%20une%20option%20pour%20(a)%20supprimer%20la%20v%C3%A9rification%20de%20la%20liste%20avant%20de%20continuer%20ou%20(b)%20abandonner%20la%20mise%20%C3%A0%20jour.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EM%C3%A9lange%20et%20nettoyage%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Table%26gt%3B%20Update%20devrait%20avertir%20lorsque%20la%20colonne%20%C3%A9chouera%20en%20raison%20de%20la%20v%C3%A9rification%20de%20la%20liste%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJe%20l'ai%20mal%20formul%C3%A9.%20L'%C3%A9chec%20se%20produit%20lorsque%20Update%20()%20est%20appel%C3%A9%20%C3%A0%20partir%20d'un%20script%20JSL.%20Je%20n'ai%20pas%20test%C3%A9%20si%20le%20comportement%20est%20diff%C3%A9rent%20lorsque%20Table%26gt%3B%20Update%20est%20appel%C3%A9%20%C3%A0%20partir%20du%20menu.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Table > Update should warn when column will fail due to List Check
When updating a target table that includes columns with a List Check property, the update on that column fails silently if the update source table contains items that are not in the target table's List Check.
I agree that the update should fail, but it should fail with a warning and an option to (a) remove the List Check before proceeding or (b) abort the update.
1 Comment
john_madden
Level VI
I phrased this poorly. The failure occurs when Update() is called from a JSL script. I have not tested whether the behavior is different when Table > Update is called from the menu.
