%3CLINGO-SUB%20id%3D%22lingo-sub-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ETabla%20%26gt%3B%20La%20actualizaci%C3%B3n%20deber%C3%ADa%20advertir%20cuando%20la%20columna%20fallar%C3%A1%20debido%20a%20la%20verificaci%C3%B3n%20de%20lista%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAl%20actualizar%20una%20tabla%20de%20destino%20que%20incluye%20columnas%20con%20una%20propiedad%20de%20verificaci%C3%B3n%20de%20lista%2C%20la%20actualizaci%C3%B3n%20en%20esa%20columna%20falla%20silenciosamente%20si%20la%20tabla%20de%20origen%20de%20la%20actualizaci%C3%B3n%20contiene%20elementos%20que%20no%20est%C3%A1n%20en%20la%20verificaci%C3%B3n%20de%20lista%20de%20la%20tabla%20de%20destino.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EAcepto%20que%20la%20actualizaci%C3%B3n%20deber%C3%ADa%20fallar%2C%20pero%20deber%C3%ADa%20fallar%20con%20una%20advertencia%20y%20una%20opci%C3%B3n%20para%20(a)%20eliminar%20la%20verificaci%C3%B3n%20de%20lista%20antes%20de%20continuar%20o%20(b)%20cancelar%20la%20actualizaci%C3%B3n.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-51781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ECombinaci%C3%B3n%20y%20limpieza%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Table%26gt%3B%20Update%20debe%20advertir%20cuando%20la%20columna%20fallar%C3%A1%20debido%20a%20la%20verificaci%C3%B3n%20de%20la%20lista%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51831%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELo%20expres%C3%A9%20mal.%20El%20error%20se%20produce%20cuando%20se%20llama%20a%20Update%20()%20desde%20un%20script%20JSL.%20No%20he%20probado%20si%20el%20comportamiento%20es%20diferente%20cuando%20se%20llama%20a%20Tabla%26gt%3B%20Actualizaci%C3%B3n%20desde%20el%20men%C3%BA.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Table > Update should warn when column will fail due to List Check
When updating a target table that includes columns with a List Check property, the update on that column fails silently if the update source table contains items that are not in the target table's List Check.
I agree that the update should fail, but it should fail with a warning and an option to (a) remove the List Check before proceeding or (b) abort the update.
1 Comment
john_madden
Level VI
I phrased this poorly. The failure occurs when Update() is called from a JSL script. I have not tested whether the behavior is different when Table > Update is called from the menu.
