%3CLINGO-SUB%20id%3D%22lingo-sub-724908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EStoppen%20Sie%20die%20automatische%20Generierung%20neuer%20Laufbl%C3%A4tter%20mit%20dem%20DOE-Dialogskript%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-724908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEine%20Sache%2C%20die%20mir%20im%20Laufe%20der%20Zeit%20beim%20Generieren%20von%20DOE-Laufbl%C3%A4ttern%20in%20JMP%20aufgefallen%20ist%2C%20ist%20das%20DOE-Dialogskript.%20Mir%20gef%C3%A4llt%2C%20dass%20es%20da%20ist%2C%20sodass%20man%20das%20Design%20leicht%20reproduzieren%20kann.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EEine%20Anpassung%2C%20die%20ich%20vornehmen%20w%C3%BCrde%2C%20besteht%20darin%2C%20das%20Design%20nicht%20tats%C3%A4chlich%20neu%20zu%20generieren%2C%20was%20m%C3%B6glicherweise%20einen%20Fortschrittsbalken%20sowie%20eine%20neue%20Kopie%20des%20Laufblatts%20ergibt.%20Ich%20denke%2C%20es%20sollte%20Sie%20zu%20den%20Eingaben%20f%C3%BChren%2C%20die%20verwendet%20wurden%2C%20bevor%20auf%20die%20Schaltfl%C3%A4che%20%E2%80%9EDesign%20erstellen%E2%80%9C%20geklickt%20wurde%2C%20da%20dies%20letztendlich%20das%20ist%2C%20was%20der%20Benutzer%20ber%C3%BCcksichtigen%20m%C3%B6chte%20(z.%20B.%20das%20Ausprobieren%20einer%20neuen%20Laufgr%C3%B6%C3%9Fe%20oder%20das%20Anpassen%20des%20Modells).%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EEs%20kann%20ablenkend%20sein%2C%20wenn%20ein%20neues%20JMP-Blatt%20angezeigt%20wird.%20Und%20in%20manchen%20F%C3%A4llen%20dauert%20die%20Fortschrittsanzeige%20zum%20Generieren%20des%20neuen%20Designs%20sehr%20lange%2C%20was%20ebenfalls%20unpraktisch%20sein%20kann.%20Dies%20sollte%20ein%20relativ%20einfaches%20Upgrade%20sein.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-724908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EVersuchsplanung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Stop generating new run sheet automatically with DOE Dialog script
One thing I’ve noticed over time with generating DOE run sheets in JMP is the DOE Dialog script. I like that it’s there so you can easily reproduce the design.
One adjustment I would make is to refrain from actually re-generating the design, which may give a progress bar as well as a new replicate of the run sheet. I think it should take you to the inputs that were being used before the ‘make design’ button is hit because that is ultimately what the user wants to consider (such as trying a new run size or adjusting the model).
It can be distracting to have a new JMP sheet pop up. And in some cases, the progress bar to generate the new design takes a long time, which can be inconvenient as well. This should be a relatively simple upgrade.
