%3CLINGO-SUB%20id%3D%22lingo-sub-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOption%20de%20conception%20Space-Filling%20pour%20une%20conception%20personnalis%C3%A9e%20avec%20covariables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EBonjour%20%C3%A0%20l'%C3%A9quipe%20JMP%20et%20aux%20membres%20de%20la%20communaut%C3%A9%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EPeut-%C3%AAtre%20que%20je%20n'ai%20pas%20cherch%C3%A9%20assez%20longtemps%2C%20mais%20il%20semble%20que%20les%20conceptions%20de%20remplissage%20d'espace%20ne%20soient%20accessibles%20que%20via%20DoE%20-%26gt%3B%20Classique%20-%26gt%3B%20M%C3%A9lange%20ou%20via%20DoE%20-%26gt%3B%20Usage%20sp%C3%A9cial%20-%26gt%3B%20Conceptions%20de%20remplissage%20d'espace.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ECependant%2C%20j'ai%20eu%20un%20cas%20o%C3%B9%20une%20conception%20de%20m%C3%A9lange%20serait%20le%20type%20de%20conception%20%C3%A0%20choisir%20(car%20les%20facteurs%20sont%20des%20composants%20dans%20une%20formulation)%20et%20une%20zone%20de%20l'espace%20exp%C3%A9rimental%20devrait%20%C3%AAtre%20exclue%20(voir%20image%2C%20la%20zone%20rouge%20est%20exclue%20en%20raison%20de%20probl%C3%A8mes%20de%20stabilit%C3%A9)%20.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EJ'ai%20essay%C3%A9%20de%20faire%20l'option%20%22Combinaisons%20non%20autoris%C3%A9es%20filtre%2Fscript%22%2C%20mais%20cela%20ne%20fonctionne%20pas%20avec%20les%20conceptions%20Mixture.%3C%2FP%3E%3CP%3EJ'ai%20%C3%A9galement%20essay%C3%A9%20la%20m%C3%A9thode%20%22Candidate%20Runs%22%2C%20en%20g%C3%A9n%C3%A9rant%20100%20000%20points%20dans%20mon%20espace%20exp%C3%A9rimental%2C%20en%20excluant%20la%20zone%20rouge%2C%20et%20en%20essayant%20de%20cr%C3%A9er%20un%20design%20personnalis%C3%A9%20avec%20des%20covariables.%20Cela%20fonctionne%2C%20mais%20j'aimerais%20pouvoir%20utiliser%20ici%20une%20conception%20Space-Filling%2C%20pour%20avoir%20plus%20de%20flexibilit%C3%A9%20dans%20la%20mod%C3%A9lisation%20et%20%C3%A9viter%20les%20%22angles%20morts%22.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJ'ai%20aussi%20essay%C3%A9%20le%20Space-Filling%20depuis%20le%20menu%20%22Special%20Purpose%22%20et%20en%20ajoutant%20les%20contraintes%2C%20mais%20tr%C3%A8s%20%C3%A9trangement%20il%20semble%20y%20avoir%20un%20bug%2C%20car%20tous%20les%20points%20g%C3%A9n%C3%A9r%C3%A9s%20sont%20%C3%A0%200.%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EDOE(%0A%20Space%20Filling%20Design%2C%0A%20%7BAdd%20Response(%20Maximize%2C%20%22Y%22%2C%20.%2C%20.%2C%20.%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X1%22%2C%200%20)%2C%0A%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X2%22%2C%200%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X3%22%2C%200%20)%2C%0A%20Set%20Random%20Seed(%201883266761%20)%2C%20Disallowed%20Combinations(%20X2%20%26gt%3B%3D%200.3%20%26amp%3B%20X1%20%26lt%3B%3D%200.2%20)%2C%0A%20FFF%20Optimality%20Criterion(%20MaxPro%20)%2C%0A%20Space%20Filling%20Design%20Type(%20Fast%20Flexible%20Filling%2C%2030%20)%2C%20Simulate%20Responses(%200%20)%7D%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EPour%20mon%20cas%20d'utilisation%2C%20je%20vais%20simplement%20g%C3%A9n%C3%A9rer%20la%20conception%20Space-Filling%20sans%20contraintes%20et%20exclure%20manuellement%20les%20points%20de%20la%20zone%20(m%C3%A9thode%20pas%20optimale%2C%20mais%20cela%20semble%20%C3%AAtre%20la%20seule%20option%20ici%20pour%20avoir%20une%20conception%20Space-FILling)%2C%20mais%20j'aimerais%20avoir%20dans%20le%20design%20personnalis%C3%A9%20la%20possibilit%C3%A9%20d'utiliser%20le%20design%20Space-Filling%20(avec%20des%20covariables%20pour%20le%20design%20de%20m%C3%A9langes%20avec%20des%20contraintes%20sp%C3%A9cifiques%20par%20exemple).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EConception%20d'exp%C3%A9riences%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Space-Filling design option for Custom design with covariates
Hi JMP team and Community members,
Maybe I haven't searched long enough, but it seems Space-Filling design are only accessible through DoE -> Classical -> Mixture or through DoE -> Special Purpose -> Space Filling Designs.
However, I had a case where a Mixture design would be the type of design to choose (because factors are components in a formulation) and an area of the experimental space should be excluded (see image, red area is excluded because of stability issues).
I tried to do the option "Disallowed combinations filter/script", but it doesn't work with Mixture designs.
I also tried the "Candidate Runs" method, by generating 100000 points in my experimental space, excluding the red area, and trying to create a Custom design with covariates. It does work, but I would like the option here to use a Space-Filling design, to have more flexibility in the modeling and avoid "blind spots".
I also tried the Space-Filling from "Special Purpose" menu and adding the constraints, but very strangely it seems to have a bug, as all generated points are at 0.
DOE(
	Space Filling Design,
	{Add Response( Maximize, "Y", ., ., . ), Add Factor( Mixture, 0, 1, "X1", 0 ),
	Add Factor( Mixture, 0, 1, "X2", 0 ), Add Factor( Mixture, 0, 1, "X3", 0 ),
	Set Random Seed( 1883266761 ), Disallowed Combinations( X2 >= 0.3 & X1 <= 0.2 ),
	FFF Optimality Criterion( MaxPro ),
	Space Filling Design Type( Fast Flexible Filling, 30 ), Simulate Responses( 0 )}
For my use case I will simply generate the Space-Filling design with no constraints and manually exclude points in the area (not optimal method, but it seems to be the only option here to have a Space-FIlling design), but I would like to have in the Custom design the option to use Space-Filling design (with covariates for Mixtures design with specific constraints for example).
