%3CLINGO-SUB%20id%3D%22lingo-sub-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOpci%C3%B3n%20de%20dise%C3%B1o%20de%20relleno%20de%20espacio%20para%20dise%C3%B1o%20personalizado%20con%20covariables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%20equipo%20JMP%20y%20miembros%20de%20la%20comunidad%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ETal%20vez%20no%20he%20buscado%20lo%20suficiente%2C%20pero%20parece%20que%20solo%20se%20puede%20acceder%20al%20dise%C3%B1o%20de%20relleno%20de%20espacio%20a%20trav%C3%A9s%20de%20DoE%20-%26gt%3B%20Cl%C3%A1sico%20-%26gt%3B%20Mezcla%20o%20a%20trav%C3%A9s%20de%20DoE%20-%26gt%3B%20Prop%C3%B3sito%20especial%20-%26gt%3B%20Dise%C3%B1os%20de%20relleno%20de%20espacio.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESin%20embargo%2C%20tuve%20un%20caso%20en%20el%20que%20un%20dise%C3%B1o%20de%20Mezcla%20ser%C3%ADa%20el%20tipo%20de%20dise%C3%B1o%20a%20elegir%20(porque%20los%20factores%20son%20componentes%20en%20una%20formulaci%C3%B3n)%20y%20se%20deber%C3%ADa%20excluir%20un%20%C3%A1rea%20del%20espacio%20experimental%20(ver%20imagen%2C%20el%20%C3%A1rea%20roja%20se%20excluye%20debido%20a%20problemas%20de%20estabilidad)%20.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EIntent%C3%A9%20hacer%20la%20opci%C3%B3n%20%22Combinaciones%20no%20permitidas%20filtro%2Fscript%22%2C%20pero%20no%20funciona%20con%20los%20dise%C3%B1os%20de%20Mixture.%3C%2FP%3E%3CP%3ETambi%C3%A9n%20prob%C3%A9%20el%20m%C3%A9todo%20%22Candidate%20Runs%22%2C%20generando%20100000%20puntos%20en%20mi%20espacio%20experimental%2C%20excluyendo%20el%20%C3%A1rea%20roja%20e%20intentando%20crear%20un%20dise%C3%B1o%20personalizado%20con%20covariables.%20Funciona%2C%20pero%20me%20gustar%C3%ADa%20la%20opci%C3%B3n%20aqu%C3%AD%20de%20usar%20un%20dise%C3%B1o%20de%20relleno%20de%20espacio%2C%20para%20tener%20m%C3%A1s%20flexibilidad%20en%20el%20modelado%20y%20evitar%20%22puntos%20ciegos%22.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ETambi%C3%A9n%20prob%C3%A9%20el%20relleno%20de%20espacio%20del%20men%C3%BA%20%22Prop%C3%B3sito%20especial%22%20y%20agregu%C3%A9%20las%20restricciones%2C%20pero%20muy%20extra%C3%B1amente%20parece%20tener%20un%20error%2C%20ya%20que%20todos%20los%20puntos%20generados%20est%C3%A1n%20en%200.%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EDOE(%0A%20Space%20Filling%20Design%2C%0A%20%7BAdd%20Response(%20Maximize%2C%20%22Y%22%2C%20.%2C%20.%2C%20.%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X1%22%2C%200%20)%2C%0A%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X2%22%2C%200%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X3%22%2C%200%20)%2C%0A%20Set%20Random%20Seed(%201883266761%20)%2C%20Disallowed%20Combinations(%20X2%20%26gt%3B%3D%200.3%20%26amp%3B%20X1%20%26lt%3B%3D%200.2%20)%2C%0A%20FFF%20Optimality%20Criterion(%20MaxPro%20)%2C%0A%20Space%20Filling%20Design%20Type(%20Fast%20Flexible%20Filling%2C%2030%20)%2C%20Simulate%20Responses(%200%20)%7D%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EPara%20mi%20caso%20de%20uso%2C%20simplemente%20generar%C3%A9%20el%20dise%C3%B1o%20Space-Filling%20sin%20restricciones%20y%20excluir%C3%A9%20manualmente%20puntos%20en%20el%20%C3%A1rea%20(m%C3%A9todo%20no%20%C3%B3ptimo%2C%20pero%20parece%20ser%20la%20%C3%BAnica%20opci%C3%B3n%20aqu%C3%AD%20para%20tener%20un%20dise%C3%B1o%20Space-Filling)%2C%20pero%20me%20gustar%C3%ADa%20tener%20en%20el%20dise%C3%B1o%20personalizado%20la%20opci%C3%B3n%20de%20usar%20el%20dise%C3%B1o%20de%20relleno%20de%20espacio%20(con%20covariables%20para%20el%20dise%C3%B1o%20de%20mezclas%20con%20restricciones%20espec%C3%ADficas%2C%20por%20ejemplo).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EDise%C3%B1o%20de%20experimentos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Space-Filling design option for Custom design with covariates
Hi JMP team and Community members,
Maybe I haven't searched long enough, but it seems Space-Filling design are only accessible through DoE -> Classical -> Mixture or through DoE -> Special Purpose -> Space Filling Designs.
However, I had a case where a Mixture design would be the type of design to choose (because factors are components in a formulation) and an area of the experimental space should be excluded (see image, red area is excluded because of stability issues).
I tried to do the option "Disallowed combinations filter/script", but it doesn't work with Mixture designs.
I also tried the "Candidate Runs" method, by generating 100000 points in my experimental space, excluding the red area, and trying to create a Custom design with covariates. It does work, but I would like the option here to use a Space-Filling design, to have more flexibility in the modeling and avoid "blind spots".
I also tried the Space-Filling from "Special Purpose" menu and adding the constraints, but very strangely it seems to have a bug, as all generated points are at 0.
DOE(
	Space Filling Design,
	{Add Response( Maximize, "Y", ., ., . ), Add Factor( Mixture, 0, 1, "X1", 0 ),
	Add Factor( Mixture, 0, 1, "X2", 0 ), Add Factor( Mixture, 0, 1, "X3", 0 ),
	Set Random Seed( 1883266761 ), Disallowed Combinations( X2 >= 0.3 & X1 <= 0.2 ),
	FFF Optimality Criterion( MaxPro ),
	Space Filling Design Type( Fast Flexible Filling, 30 ), Simulate Responses( 0 )}
For my use case I will simply generate the Space-Filling design with no constraints and manually exclude points in the area (not optimal method, but it seems to be the only option here to have a Space-FIlling design), but I would like to have in the Custom design the option to use Space-Filling design (with covariates for Mixtures design with specific constraints for example).
