%3CLINGO-SUB%20id%3D%22lingo-sub-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERaumf%C3%BCllende%20Entwurfsoption%20f%C3%BCr%20benutzerdefiniertes%20Design%20mit%20Kovariaten%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%20JMP-Team%20und%20Community-Mitglieder%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EVielleicht%20habe%20ich%20nicht%20lange%20genug%20gesucht%2C%20aber%20es%20scheint%2C%20dass%20raumf%C3%BCllende%20Designs%20nur%20%C3%BCber%20DoE%20-%26gt%3B%20Klassik%20-%26gt%3B%20Mischung%20oder%20%C3%BCber%20DoE%20-%26gt%3B%20Spezialzweck%20-%26gt%3B%20raumf%C3%BCllende%20Designs%20zug%C3%A4nglich%20sind.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIch%20hatte%20jedoch%20einen%20Fall%2C%20in%20dem%20ein%20Mixture-Design%20der%20zu%20w%C3%A4hlende%20Designtyp%20w%C3%A4re%20(da%20Faktoren%20Komponenten%20in%20einer%20Formulierung%20sind)%20und%20ein%20Bereich%20des%20experimentellen%20Raums%20ausgeschlossen%20werden%20sollte%20(siehe%20Bild%2C%20roter%20Bereich%20ist%20aufgrund%20von%20Stabilit%C3%A4tsproblemen%20ausgeschlossen).%20.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EIch%20habe%20versucht%2C%20die%20Option%20%E2%80%9EUnzul%C3%A4ssige%20Kombinationen%20Filter%2FSkript%E2%80%9C%20zu%20aktivieren%2C%20aber%20sie%20funktioniert%20nicht%20mit%20Mixture-Designs.%3C%2FP%3E%3CP%3EIch%20habe%20auch%20die%20Methode%20%E2%80%9ECandidate%20Runs%E2%80%9C%20ausprobiert%2C%20indem%20ich%20100.000%20Punkte%20in%20meinem%20experimentellen%20Raum%20generiert%20habe%2C%20den%20roten%20Bereich%20ausgenommen%2C%20und%20versucht%20habe%2C%20ein%20benutzerdefiniertes%20Design%20mit%20Kovariaten%20zu%20erstellen.%20Es%20funktioniert%20zwar%2C%20aber%20ich%20w%C3%BCrde%20mir%20hier%20die%20M%C3%B6glichkeit%20w%C3%BCnschen%2C%20ein%20raumf%C3%BCllendes%20Design%20zu%20verwenden%2C%20um%20mehr%20Flexibilit%C3%A4t%20bei%20der%20Modellierung%20zu%20haben%20und%20%E2%80%9Etote%20Winkel%E2%80%9C%20zu%20vermeiden.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIch%20habe%20auch%20die%20Raumf%C3%BCllung%20aus%20dem%20Men%C3%BC%20%E2%80%9ESpezieller%20Zweck%E2%80%9C%20ausprobiert%20und%20die%20Einschr%C3%A4nkungen%20hinzugef%C3%BCgt%2C%20aber%20seltsamerweise%20scheint%20es%20einen%20Fehler%20zu%20geben%2C%20da%20alle%20generierten%20Punkte%20auf%200%20sind.%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EDOE(%0A%20Space%20Filling%20Design%2C%0A%20%7BAdd%20Response(%20Maximize%2C%20%22Y%22%2C%20.%2C%20.%2C%20.%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X1%22%2C%200%20)%2C%0A%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X2%22%2C%200%20)%2C%20Add%20Factor(%20Mixture%2C%200%2C%201%2C%20%22X3%22%2C%200%20)%2C%0A%20Set%20Random%20Seed(%201883266761%20)%2C%20Disallowed%20Combinations(%20X2%20%26gt%3B%3D%200.3%20%26amp%3B%20X1%20%26lt%3B%3D%200.2%20)%2C%0A%20FFF%20Optimality%20Criterion(%20MaxPro%20)%2C%0A%20Space%20Filling%20Design%20Type(%20Fast%20Flexible%20Filling%2C%2030%20)%2C%20Simulate%20Responses(%200%20)%7D%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EF%C3%BCr%20meinen%20Anwendungsfall%20erstelle%20ich%20einfach%20das%20raumf%C3%BCllende%20Design%20ohne%20Einschr%C3%A4nkungen%20und%20schlie%C3%9Fe%20manuell%20Punkte%20im%20Bereich%20aus%20(keine%20optimale%20Methode%2C%20aber%20es%20scheint%20hier%20die%20einzige%20Option%20f%C3%BCr%20ein%20raumf%C3%BCllendes%20Design%20zu%20sein)%2C%20aber%20ich%20w%C3%BCrde%20es%20gerne%20tun%20im%20benutzerdefinierten%20Design%20die%20Option%20zu%20haben%2C%20raumf%C3%BCllendes%20Design%20zu%20verwenden%20(z.%20B.%20mit%20Kovariaten%20f%C3%BCr%20Mischungsdesign%20mit%20spezifischen%20Einschr%C3%A4nkungen).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-581846%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EVersuchsplanung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Space-Filling design option for Custom design with covariates
Hi JMP team and Community members,
Maybe I haven't searched long enough, but it seems Space-Filling design are only accessible through DoE -> Classical -> Mixture or through DoE -> Special Purpose -> Space Filling Designs.
However, I had a case where a Mixture design would be the type of design to choose (because factors are components in a formulation) and an area of the experimental space should be excluded (see image, red area is excluded because of stability issues).
I tried to do the option "Disallowed combinations filter/script", but it doesn't work with Mixture designs.
I also tried the "Candidate Runs" method, by generating 100000 points in my experimental space, excluding the red area, and trying to create a Custom design with covariates. It does work, but I would like the option here to use a Space-Filling design, to have more flexibility in the modeling and avoid "blind spots".
I also tried the Space-Filling from "Special Purpose" menu and adding the constraints, but very strangely it seems to have a bug, as all generated points are at 0.
DOE(
	Space Filling Design,
	{Add Response( Maximize, "Y", ., ., . ), Add Factor( Mixture, 0, 1, "X1", 0 ),
	Add Factor( Mixture, 0, 1, "X2", 0 ), Add Factor( Mixture, 0, 1, "X3", 0 ),
	Set Random Seed( 1883266761 ), Disallowed Combinations( X2 >= 0.3 & X1 <= 0.2 ),
	FFF Optimality Criterion( MaxPro ),
	Space Filling Design Type( Fast Flexible Filling, 30 ), Simulate Responses( 0 )}
For my use case I will simply generate the Space-Filling design with no constraints and manually exclude points in the area (not optimal method, but it seems to be the only option here to have a Space-FIlling design), but I would like to have in the Custom design the option to use Space-Filling design (with covariates for Mixtures design with specific constraints for example).
