%3CLINGO-SUB%20id%3D%22lingo-sub-446852%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMostrar%20n%C3%BAmeros%20de%20fila%20en%20la%20vista%20previa%20del%20editor%20de%20f%C3%B3rmulas%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-446852%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EProporcione%20el%20n%C3%BAmero%20de%20fila%20a%20los%20editores%20de%20f%C3%B3rmulas.%20Ventana%20de%20vista%20previa.%20Esto%20podr%C3%ADa%20facilitar%20la%20depuraci%C3%B3n%20de%20f%C3%B3rmulas%20cuando%20tenga%20un%20posible%20problema%20dentro%20de%20la%20subexpresi%C3%B3n.%20Tendr%C3%ADa%20que%20averiguar%20c%C3%B3mo%20mostrar%20los%20n%C3%BAmeros%20de%20fila%20al%20usar%20Random%20n%2C%20estar%C3%ADa%20bien%20con%20los%20n%C3%BAmeros%20de%20fila%20%22reales%22%20de%20la%20tabla%20de%20datos.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-446852%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EScripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Show row numbers in formula editor preview
Provide row number to formula editors Preview window. This could make it easier to debug formulas when you have a possible problem within subexpression. Would have to figure out how to show row numbers when using Random n, I would be fine with "real" row numbers from datatable.
