  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
%3CLINGO-SUB%20id%3D%22lingo-sub-620709%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EEnvoyer%20directement%20le%20graphique%20avec%20le%20script%20d'alarme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-620709%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EJ'ai%20re%C3%A7u%20beaucoup%20de%20soutien%20de%20la%20part%20de%20l'%C3%A9quipe%20JMP%2C%20notamment%20de%20la%20part%20de%20Jed.%3C%2FP%3E%3CP%3EJe%20voudrais%20sugg%C3%A9rer%20%C3%A0%20JMP%20de%20prendre%20en%20charge%20la%20carte%20de%20contr%C3%B4le%20%C3%A0%20int%C3%A9grer%20directement%20dans%20l'e-mail%20avec%20le%20script%20d'alarme.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EActuellement%2C%20le%20script%20d'alarme%20par%20e-mail%20ne%20prend%20pas%20en%20charge%20le%20graphique%20int%C3%A9gr%C3%A9%20dans%20l'e-mail%2C%20le%20script%20d'alarme%20prend%20en%20charge%20le%20substitut%2C%20le%20test%20QC%20et%20le%20fichier%20joint.%20Cependant%2C%20nous%20aimerions%20avoir%20un%20graphique%20%C3%A0%20afficher%20directement%20dans%20l'e-mail%20pour%20permettre%20aux%20gens%20de%20lire%20facilement%20l'e-mail.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EPour%20l'alarme%20SPC%2C%20nous%20souhaitons%20que%20les%20gens%20soient%20inform%C3%A9s%20imm%C3%A9diatement%20de%20l'article%20QC%2Fdu%20dispositif%20QC%2Fdu%20lot%20QC%20au%20lieu%20d'ouvrir%20le%20fichier.%20Dans%20un%20souci%20de%20convivialit%C3%A9%2C%20j'esp%C3%A8re%20que%20JMP%20pourra%20envisager%20d'int%C3%A9grer%20cette%20fonction%20%C3%A0%20la%20carte%20de%20contr%C3%B4le%20directement%20dans%20le%20courrier%20%C3%A9lectronique.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-620709%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EPersonnalisation%20de%20masse%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-627360%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Envoyer%20directement%20le%20graphique%20avec%20le%20script%20d'alarme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-627360%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EVoici%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FControl-chart-warning-email%2Fm-p%2F610474%22%20target%3D%22_self%22%3E%20le%20fil%20de%20discussion%20original%3C%2FA%3E%20pour%20r%C3%A9f%C3%A9rence.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-627299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Envoyer%20directement%20le%20graphique%20avec%20le%20script%20d'alarme%20-%20Statut%20modifi%C3%A9%20en%26nbsp%3B%3A%20Besoin%20d'informations%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-627299%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMerci%20pour%20cette%20demande%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F46712%22%20target%3D%22_blank%22%3E%20%40Lichun%3C%2FA%3E%20%2C%20et%20pour%20votre%20soutien%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F610%22%20target%3D%22_blank%22%3E%20%40Jed_Campbell%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3EPouvez-vous%20s'il%20vous%20pla%C3%AEt%20fournir%20des%20informations%20suppl%C3%A9mentaires%20%3F%20Cette%20demande%20est-elle%20li%C3%A9e%20aux%20avertissements%20des%20cartes%20de%20contr%C3%B4le%20dans%20HTML5%20et%2Fou%20JMP%20Live%26nbsp%3B%3F%20Pouvez-vous%20donner%20un%20exemple%20du%20changement%20que%20vous%20aimeriez%20voir%26nbsp%3B%3F%3C%2FP%3E%0A%3CP%3EMerci!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-623474%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Envoyer%20directement%20le%20graphique%20avec%20le%20script%20d'alarme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-623474%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EPuis-je%20%C3%A9galement%20ajouter%20%C3%A0%20cette%20excellente%20suggestion%20qu'une%20option%20soit%20cr%C3%A9%C3%A9e%20pour%20simplement%20cr%C3%A9er%20l'e-mail%20plut%C3%B4t%20que%20de%20l'envoyer%20directement%26nbsp%3B%3FDe%20cette%20fa%C3%A7on%2C%20si%20vous%20devez%20effectuer%20des%20ajustements%20manuels%2C%20vous%20avez%20la%20possibilit%C3%A9%20de%20le%20faire.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E
Send the chart with alarm script directly
I got a lot of support from JMP team, especially from Jed.
I would like to suggest JMP to support control chart to embedded in the email with alarm script directly.
Currently the email alarm script not support the chart embedded in the email, alarm script support the substitue, QC test, attached file. However, we would like to have chart to show in email directly to make people easy to read the email.
Why is this idea important?
For the SPC alarm that we would people to aware of the QC item/ QC device/ QC lot immediately instead of people need to open the file. With the purpose of user friendly, I hope JMP can consider to have this function to embedded control chart directly in email.
Thanks.
3 Comments
shampton82
Level VII
Can I also add to this great suggestion that an option be created to just create the email vs directly sending it out?  That way if there is some manual tweaking you need to do you have the option for it.
Thanks
Steve
mia_stephens
Status changed to: Needs Info
Thank you for this request @Lichun , and for your support @Jed_Campbell.
Can you please provide additional information? Is this request related to control chart warnings in HTML5 and/or JMP Live? Can you provide an example of the change you'd like to see?
Thank you!
Jed_Campbell
Here's the original discussion thread for reference.
