%3CLINGO-SUB%20id%3D%22lingo-sub-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAsse%20Y%20secondario%20destro%20per%20il%20Costruttore%20di%20grafici%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%C3%88%20possibile%20migliorare%20il%20Costruttore%20di%20grafici%20per%20aggiungere%20un%20asse%20Y%20numerico%20secondario%20sul%20lato%20destro%20con%20le%20stesse%20caratteristiche%20e%20funzionalit%C3%A0%20di%20quello%20primario%3F%20La%20soluzione%20attuale%20prevede%20il%20trascinamento%20delle%20variabili%20sull'asse%20di%20sinistra%2C%20la%20formattazione%20secondo%20necessit%C3%A0%20e%20quindi%20lo%20spostamento%20a%20destra.%20In%20alcuni%20casi%2C%20ci%C3%B2%20pu%C3%B2%20diventare%20complicato%2Fcontorto%20e%20avere%20un%20asse%20dedicato%20(separato%20dalla%20Categoria%20Y%20gi%C3%A0%20disponibile)%20sarebbe%20estremamente%20utile.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EGrazie%20e%20saluti%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3CP%3Ecc%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10483%22%20target%3D%22_blank%22%3E%20%40PatrickGiuliano%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20Asse%20Y%20secondario%20destro%20per%20il%20Costruttore%20di%20grafici%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Right-side Secondary Y-axis for Graph Builder
Hello,
Can Graph Builder be enhanced to add a numeric secondary Y-axis on the right side with the same features and capabilities as the primary one? The current workaround involves dragging the variables to the left-side axis, formatting them as needed, and then moving them right. In some cases, that can get cumbersome / convoluted and having a dedicated axis (separate from the already available Category Y) would be extremely helpful.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
1 Comment
