%3CLINGO-SUB%20id%3D%22lingo-sub-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAxe%20Y%20secondaire%20de%20droite%20pour%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EBonjour%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGraph%20Builder%20peut-il%20%C3%AAtre%20am%C3%A9lior%C3%A9%20pour%20ajouter%20un%20axe%20Y%20secondaire%20num%C3%A9rique%20sur%20le%20c%C3%B4t%C3%A9%20droit%20avec%20les%20m%C3%AAmes%20fonctionnalit%C3%A9s%20et%20capacit%C3%A9s%20que%20l'axe%20Y%20principal%26nbsp%3B%3F%20La%20solution%20de%20contournement%20actuelle%20consiste%20%C3%A0%20faire%20glisser%20les%20variables%20vers%20l'axe%20de%20gauche%2C%20%C3%A0%20les%20formater%20selon%20les%20besoins%2C%20puis%20%C3%A0%20les%20d%C3%A9placer%20vers%20la%20droite.%20Dans%20certains%20cas%2C%20cela%20peut%20devenir%20fastidieux%2Falambiqu%C3%A9%20et%20disposer%20d'un%20axe%20d%C3%A9di%C3%A9%20(s%C3%A9par%C3%A9%20de%20la%20cat%C3%A9gorie%20Y%20d%C3%A9j%C3%A0%20disponible)%20serait%20extr%C3%AAmement%20utile.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EMerci%20et%20salutations%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3CP%3Ecc%26nbsp%3B%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10483%22%20target%3D%22_blank%22%3E%20%40PatrickGiuliano%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EExploration%20et%20visualisation%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20Axe%20Y%20secondaire%20de%20droite%20pour%20Graph%20Builder%26nbsp%3B%E2%80%93%26nbsp%3BStatut%20modifi%C3%A9%20en%26nbsp%3B%3A%20Acquitt%C3%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Right-side Secondary Y-axis for Graph Builder
Hello,
Can Graph Builder be enhanced to add a numeric secondary Y-axis on the right side with the same features and capabilities as the primary one? The current workaround involves dragging the variables to the left-side axis, formatting them as needed, and then moving them right. In some cases, that can get cumbersome / convoluted and having a dedicated axis (separate from the already available Category Y) would be extremely helpful.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
1 Comment
