%3CLINGO-SUB%20id%3D%22lingo-sub-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EEje%20Y%20secundario%20derecho%20para%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%C2%BFSe%20puede%20mejorar%20Graph%20Builder%20para%20agregar%20un%20eje%20Y%20secundario%20num%C3%A9rico%20en%20el%20lado%20derecho%20con%20las%20mismas%20caracter%C3%ADsticas%20y%20capacidades%20que%20el%20principal%3F%20La%20soluci%C3%B3n%20actual%20implica%20arrastrar%20las%20variables%20al%20eje%20del%20lado%20izquierdo%2C%20formatearlas%20seg%C3%BAn%20sea%20necesario%20y%20luego%20moverlas%20hacia%20la%20derecha.%20En%20algunos%20casos%2C%20esto%20puede%20resultar%20engorroso%2Fcomplicado%20y%20tener%20un%20eje%20dedicado%20(separado%20de%20la%20Categor%C3%ADa%20Y%20ya%20disponible)%20ser%C3%ADa%20extremadamente%20%C3%BAtil.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EGracias%20y%20saludos%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3CP%3ECC%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10483%22%20target%3D%22_blank%22%3E%20%40PatrickGiuliano%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Eje%20Y%20secundario%20derecho%20para%20Graph%20Builder%20-%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Right-side Secondary Y-axis for Graph Builder
Hello,
Can Graph Builder be enhanced to add a numeric secondary Y-axis on the right side with the same features and capabilities as the primary one? The current workaround involves dragging the variables to the left-side axis, formatting them as needed, and then moving them right. In some cases, that can get cumbersome / convoluted and having a dedicated axis (separate from the already available Category Y) would be extremely helpful.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
1 Comment
