%3CLINGO-SUB%20id%3D%22lingo-sub-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERechte%20sekund%C3%A4re%20Y-Achse%20f%C3%BCr%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EKann%20Graph%20Builder%20erweitert%20werden%2C%20um%20auf%20der%20rechten%20Seite%20eine%20numerische%20sekund%C3%A4re%20Y-Achse%20mit%20denselben%20Funktionen%20und%20F%C3%A4higkeiten%20wie%20die%20prim%C3%A4re%20Achse%20hinzuzuf%C3%BCgen%3F%20Die%20aktuelle%20Problemumgehung%20besteht%20darin%2C%20die%20Variablen%20auf%20die%20linke%20Achse%20zu%20ziehen%2C%20sie%20nach%20Bedarf%20zu%20formatieren%20und%20sie%20dann%20nach%20rechts%20zu%20verschieben.%20In%20manchen%20F%C3%A4llen%20kann%20das%20umst%C3%A4ndlich%2Fkompliziert%20sein%20und%20eine%20eigene%20Achse%20(getrennt%20von%20der%20bereits%20verf%C3%BCgbaren%20Kategorie%20Y)%20w%C3%A4re%20%C3%A4u%C3%9Ferst%20hilfreich.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EDanke%20und%20Gr%C3%BC%C3%9Fe%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3CP%3ECC%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10483%22%20target%3D%22_blank%22%3E%20%40PatrickGiuliano%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-628027%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EDatenexploration%20und%20-visualisierung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Rechte%20sekund%C3%A4re%20Y-Achse%20f%C3%BCr%20Graph%20Builder%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Best%C3%A4tigt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Right-side Secondary Y-axis for Graph Builder
Hello,
Can Graph Builder be enhanced to add a numeric secondary Y-axis on the right side with the same features and capabilities as the primary one? The current workaround involves dragging the variables to the left-side axis, formatting them as needed, and then moving them right. In some cases, that can get cumbersome / convoluted and having a dedicated axis (separate from the already available Category Y) would be extremely helpful.
Thanks and regards
Mehul Shroff
cc: @PatrickGiuliano
1 Comment
