%3CLINGO-SUB%20id%3D%22lingo-sub-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERicodifica%20nomi%20colonna%3A%20solo%20le%20colonne%20selezionate%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESarebbe%20utile%20poter%20ricodificare%20i%20nomi%20delle%20colonne%2C%20ma%20solo%20quelli%20selezionati.Spesso%20con%20set%20di%20dati%20pi%C3%B9%20grandi%20c'%C3%A8%20solo%20un%20sottoinsieme%20di%20colonne%20che%20deve%20essere%20modificato%20o%20c'%C3%A8%20una%20variet%C3%A0%20di%20convenzioni%20di%20denominazione%20utilizzate.In%20questi%20casi%20la%20possibilit%C3%A0%20di%20ricodificare%20un%20sottoinsieme%20consentirebbe%20una%20maggiore%20personalizzazione%20con%20lo%20strumento%20di%20ricodifica.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Recode Column Names- Only selected columns
It would be useful to be able to recode column names, but only ones that are selected.  Often with larger data sets there is only a subset of columns that need to be modified or there is a variety of naming conventions used.  In these cases being able to recode a subset would allow for more customization with the recode tool.
