%3CLINGO-SUB%20id%3D%22lingo-sub-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERecoder%20les%20noms%20de%20colonnes%20-%20Seulement%20les%20colonnes%20s%C3%A9lectionn%C3%A9es%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIl%20serait%20utile%20de%20pouvoir%20recoder%20les%20noms%20de%20colonnes%2C%20mais%20uniquement%20ceux%20qui%20sont%20s%C3%A9lectionn%C3%A9s.Souvent%2C%20avec%20des%20ensembles%20de%20donn%C3%A9es%20plus%20volumineux%2C%20seul%20un%20sous-ensemble%20de%20colonnes%20doit%20%C3%AAtre%20modifi%C3%A9%20ou%20diff%C3%A9rentes%20conventions%20de%20d%C3%A9nomination%20sont%20utilis%C3%A9es.Dans%20ces%20cas%2C%20le%20fait%20de%20pouvoir%20recoder%20un%20sous-ensemble%20permettrait%20une%20plus%20grande%20personnalisation%20avec%20l'outil%20de%20recodage.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-357161%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Recode Column Names- Only selected columns
It would be useful to be able to recode column names, but only ones that are selected.  Often with larger data sets there is only a subset of columns that need to be modified or there is a variety of naming conventions used.  In these cases being able to recode a subset would allow for more customization with the recode tool.
