%3CLINGO-SUB%20id%3D%22lingo-sub-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOpzioni%20aggiuntive%20per%20l'analisi%20delle%20partizioni%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%20team%20JMP%2C%3C%2FP%3E%3CP%3EVorrei%20suggerire%20le%20seguenti%20opzioni%20per%20la%20piattaforma%20di%20partizione%3A%3C%2FP%3E%3CUL%3E%3CLI%3EUn%20pulsante%20per%20ricominciare%20in%20modo%20da%20non%20dover%20premere%20il%20pulsante%20Prune%20un%20sacco%20di%20volte%20per%20riavviare%20un%20albero%3C%2FLI%3E%3CLI%3EUna%20capacit%C3%A0%20di%20impostare%20la%20dimensione%20minima%20di%20suddivisione%20su%20una%20%25%20della%20quantit%C3%A0%20di%20N%20di%20addestramento%20rispetto%20all'opzione%20corrente%20di%20solo%20un%20numero%20statico%3C%2FLI%3E%3CLI%3ELa%20possibilit%C3%A0%20di%20interrompere%20la%20suddivisione%20su%20un%20valore%20di%20logworth%20(ad%20esempio%2C%20non%20dividere%20se%20il%20logworth%20di%20suddivisioni%20%C3%A8%20inferiore%20a%202)%3C%2FLI%3E%3CLI%3ELa%20possibilit%C3%A0%20di%20evidenziare%20le%20righe%20nella%20tabella%20dati%20facendo%20clic%20sulla%20riga%20del%20report%20foglia%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGrazie%20per%20aver%20preso%20in%20considerazione%20queste%20richieste!%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiche%20e%20analisi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Partition Analysis additional options
Hello JMP team,
I'd like to suggest the following options for the partition platform:
  • A start over button so that you don't have to press the Prune button a bunch of times to restart a tree
  • An ability to set the minimum split size to a % of the training N qty vs the current option of just a static number
  • The ability to stop splitting on a logworth value (for example, don't split if the splits logworth is below 2)
  • The ability to highlight the rows in the datatable by clicking on the row of the leaf report
Thanks for considering these requests!
Steve
