%3CLINGO-SUB%20id%3D%22lingo-sub-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOpciones%20adicionales%20de%20an%C3%A1lisis%20de%20particiones%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%20equipo%20de%20JMP%2C%3C%2FP%3E%3CP%3EMe%20gustar%C3%ADa%20sugerir%20las%20siguientes%20opciones%20para%20la%20plataforma%20de%20partici%C3%B3n%3A%3C%2FP%3E%3CUL%3E%3CLI%3EUn%20bot%C3%B3n%20para%20comenzar%20de%20nuevo%20para%20que%20no%20tenga%20que%20presionar%20el%20bot%C3%B3n%20Podar%20un%20mont%C3%B3n%20de%20veces%20para%20reiniciar%20un%20%C3%A1rbol%3C%2FLI%3E%3CLI%3ELa%20capacidad%20de%20establecer%20el%20tama%C3%B1o%20de%20divisi%C3%B3n%20m%C3%ADnimo%20en%20un%25%20de%20la%20cantidad%20de%20N%20de%20entrenamiento%20frente%20a%20la%20opci%C3%B3n%20actual%20de%20solo%20un%20n%C3%BAmero%20est%C3%A1tico%3C%2FLI%3E%3CLI%3ELa%20capacidad%20de%20dejar%20de%20dividir%20en%20un%20valor%20logworth%20(por%20ejemplo%2C%20no%20dividir%20si%20el%20logworth%20dividido%20est%C3%A1%20por%20debajo%20de%202)%3C%2FLI%3E%3CLI%3ELa%20capacidad%20de%20resaltar%20las%20filas%20en%20la%20tabla%20de%20datos%20haciendo%20clic%20en%20la%20fila%20del%20informe%20hoja%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%C2%A1Gracias%20por%20considerar%20estas%20solicitudes!%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EEstad%C3%ADsticas%20y%20anal%C3%ADticas%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Partition Analysis additional options
Hello JMP team,
I'd like to suggest the following options for the partition platform:
  • A start over button so that you don't have to press the Prune button a bunch of times to restart a tree
  • An ability to set the minimum split size to a % of the training N qty vs the current option of just a static number
  • The ability to stop splitting on a logworth value (for example, don't split if the splits logworth is below 2)
  • The ability to highlight the rows in the datatable by clicking on the row of the leaf report
Thanks for considering these requests!
Steve
