%3CLINGO-SUB%20id%3D%22lingo-sub-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EZus%C3%A4tzliche%20Optionen%20f%C3%BCr%20die%20Partitionsanalyse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%20JMP-Team%2C%3C%2FP%3E%3CP%3EIch%20m%C3%B6chte%20die%20folgenden%20Optionen%20f%C3%BCr%20die%20Partitionsplattform%20vorschlagen%3A%3C%2FP%3E%3CUL%3E%3CLI%3EEine%20Neustart-Taste%2C%20damit%20Sie%20die%20Prune-Taste%20nicht%20mehrmals%20dr%C3%BCcken%20m%C3%BCssen%2C%20um%20einen%20Baum%20neu%20zu%20starten%3C%2FLI%3E%3CLI%3EM%C3%B6glichkeit%2C%20die%20minimale%20Teilungsgr%C3%B6%C3%9Fe%20auf%20einen%20Prozentsatz%20der%20Trainings-N-Menge%20festzulegen%2C%20im%20Vergleich%20zur%20aktuellen%20Option%20nur%20einer%20statischen%20Zahl%3C%2FLI%3E%3CLI%3EDie%20M%C3%B6glichkeit%2C%20die%20Aufteilung%20bei%20einem%20Logwert-Wert%20zu%20beenden%20(z.%20B.%20nicht%20teilen%2C%20wenn%20der%20Aufteilungs-Logwert%20unter%202%20liegt)%3C%2FLI%3E%3CLI%3EDie%20M%C3%B6glichkeit%2C%20die%20Zeilen%20in%20der%20Datentabelle%20hervorzuheben%2C%20indem%20Sie%20auf%20die%20Zeile%20des%20Blattberichts%20klicken%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EDanke%2C%20dass%20Sie%20diese%20Anfragen%20ber%C3%BCcksichtigen!%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-448540%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiken%20und%20Analysen%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Partition Analysis additional options
Hello JMP team,
I'd like to suggest the following options for the partition platform:
  • A start over button so that you don't have to press the Prune button a bunch of times to restart a tree
  • An ability to set the minimum split size to a % of the training N qty vs the current option of just a static number
  • The ability to stop splitting on a logworth value (for example, don't split if the splits logworth is below 2)
  • The ability to highlight the rows in the datatable by clicking on the row of the leaf report
Thanks for considering these requests!
Steve
