%3CLINGO-SUB%20id%3D%22lingo-sub-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EOpzione%20per%20rimuovere%20o%20aggiungere%20la%20standardizzazione%20X%20per%20i%20grafici%20di%20smoothing%20in%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EGraph%20Builder%20ha%20codificato%20la%20standardizzazione%20X%20per%20i%20suoi%20grafici%20di%20smoothing.%3C%2FP%3E%0A%3CP%3ESarebbe%20bello%20avere%20la%20possibilit%C3%A0%20di%20attivare%20o%20disattivare%20questa%20opzione%2C%20come%20avviene%20con%20i%20grafici%20bivariati.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-535130%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opzione%20per%20rimuovere%20o%20aggiungere%20la%20standardizzazione%20X%20per%20Smoothing%20Plots%20in%20Graph%20Builder%20-%20Stato%20modificato%20in%3A%20Necessita%20di%20informazioni%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-535130%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20non%20%C3%A8%20chiaro%20cosa%20intendi%20per%20%22standardizzazione%20hardcoded%20X%22.Puoi%20spiegare%20pi%C3%B9%20in%20dettaglio%20cosa%20vuoi%20fare%20e%20perch%C3%A9%3FGrazie.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-538218%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opzione%20per%20rimuovere%20o%20aggiungere%20la%20standardizzazione%20X%20per%20Smoothing%20Plots%20in%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-538218%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20sei%20stato%20in%20grado%20di%20considerare%20questo%20e%20fornire%20maggiori%20informazioni%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-551979%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opzione%20per%20rimuovere%20o%20aggiungere%20la%20standardizzazione%20X%20per%20smoothing%20plots%20in%20Graph%20Builder%20-%20Stato%20modificato%20in%3A%20Non%20pianificato%20per%20ora%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-551979%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20-%20Modificare%20questo%20in%20%22Non%20pianificato%20per%20ora%22%20poich%C3%A9%20abbiamo%20bisogno%20di%20ulteriori%20informazioni%20per%20valutare%20la%20richiesta.%20Se%20fornisci%20maggiori%20informazioni%2C%20lo%20riapriremo.%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Option to remove or add standardization X for Smoothing Plots in Graph Builder
Graph Builder has hardcoded standardization X for its smoothing plots.
It would be nice to have an option to turn this on or off, similar with Bivariate charts.
3 Comments
SamGardner
Level VII
Status changed to: Needs Info
@shaira it is unclear what you mean by "hardcoded standardization X".  Can you explain in more detail what you want to do and why?  Thanks.
SamGardner
Level VII
@shaira have you been able to consider this and provide more information?
Status changed to: Not Planned For Now
@shaira - Changing this to "Not Planned for Now" as we need more information to evaluate the request.  If you provide more information, we will re-open it.
