%3CLINGO-SUB%20id%3D%22lingo-sub-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EOpci%C3%B3n%20para%20eliminar%20o%20agregar%20estandarizaci%C3%B3n%20X%20para%20suavizar%20gr%C3%A1ficos%20en%20el%20generador%20de%20gr%C3%A1ficos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EGraph%20Builder%20tiene%20codificada%20la%20estandarizaci%C3%B3n%20X%20para%20sus%20gr%C3%A1ficos%20de%20suavizado.%3C%2FP%3E%0A%3CP%3ESer%C3%ADa%20bueno%20tener%20una%20opci%C3%B3n%20para%20activar%20o%20desactivar%20esto%2C%20similar%20a%20los%20gr%C3%A1ficos%20bivariados.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-534880%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAn%C3%A1lisis%20y%20modelado%20de%20datos%20b%C3%A1sicos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-535130%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opci%C3%B3n%20para%20eliminar%20o%20agregar%20estandarizaci%C3%B3n%20X%20para%20suavizar%20gr%C3%A1ficos%20en%20Graph%20Builder%20-%20Estado%20cambiado%20a%3A%20Necesita%20informaci%C3%B3n%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-535130%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20no%20est%C3%A1%20claro%20qu%C3%A9%20quiere%20decir%20con%20%22estandarizaci%C3%B3n%20codificada%20X%22.%C2%BFPuedes%20explicar%20con%20m%C3%A1s%20detalle%20lo%20que%20quieres%20hacer%20y%20por%20qu%C3%A9%3FGracias.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-538218%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opci%C3%B3n%20para%20eliminar%20o%20agregar%20estandarizaci%C3%B3n%20X%20para%20suavizar%20gr%C3%A1ficos%20en%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-538218%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20%C2%BFHa%20podido%20considerar%20esto%20y%20proporcionar%20m%C3%A1s%20informaci%C3%B3n%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-551979%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Opci%C3%B3n%20para%20eliminar%20o%20agregar%20estandarizaci%C3%B3n%20X%20para%20suavizar%20gr%C3%A1ficos%20en%20Graph%20Builder%20-%20Estado%20cambiado%20a%3A%20No%20planificado%20por%20ahora%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-551979%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8603%22%20target%3D%22_blank%22%3E%40shaira%3C%2FA%3E%20-%20Cambiando%20esto%20a%20%22No%20planeado%20por%20ahora%22%20ya%20que%20necesitamos%20m%C3%A1s%20informaci%C3%B3n%20para%20evaluar%20la%20solicitud.%20Si%20proporciona%20m%C3%A1s%20informaci%C3%B3n%2C%20lo%20volveremos%20a%20abrir.%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Option to remove or add standardization X for Smoothing Plots in Graph Builder
Graph Builder has hardcoded standardization X for its smoothing plots.
It would be nice to have an option to turn this on or off, similar with Bivariate charts.
3 Comments
SamGardner
Level VII
Status changed to: Needs Info
@shaira it is unclear what you mean by "hardcoded standardization X".  Can you explain in more detail what you want to do and why?  Thanks.
SamGardner
Level VII
@shaira have you been able to consider this and provide more information?
Status changed to: Not Planned For Now
@shaira - Changing this to "Not Planned for Now" as we need more information to evaluate the request.  If you provide more information, we will re-open it.
