%3CLINGO-SUB%20id%3D%22lingo-sub-746949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOption%20permettant%20de%20faire%20fonctionner%20le%20filtre%20de%20donn%C3%A9es%20conditionnel%20de%20haut%20en%20bas%20au%20lieu%20de%20l'ordre%20de%20s%C3%A9lection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-746949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CEM%3EIl%20existe%20de%20nombreux%20%C3%A9l%C3%A9ments%20de%20liste%20de%20souhaits%20concernant%20les%20filtres%20de%20donn%C3%A9es%2C%20mais%20v%C3%A9rifiez%20rapidement%20que%20je%20n'en%20ai%20pas%20trouv%C3%A9%20exactement%20comme%20celui-ci.%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EUtiliser%20un%20filtre%20de%20donn%C3%A9es%20conditionnel%20tr%C3%A8s%20utile%20et%20r%C3%A9aliser%20que%20cela%20d%C3%A9pend%20beaucoup%20de%20l'ordre.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EUne%20option%20qui%20me%20permettrait%20de%20forcer%20l'ordre%20du%20filtre%20de%20donn%C3%A9es%20conditionnel%20de%20haut%20en%20bas%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EDonne%20plus%20de%20flexibilit%C3%A9%20aux%20filtres%20de%20donn%C3%A9es%20conditionnels%20et%20les%20rend%20plus%20conviviaux%20(%C3%A0%20mon%20avis).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-746949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EOrganisation%20du%20contenu%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EExploration%20et%20visualisation%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EPartager%20et%20communiquer%20les%20r%C3%A9sultats%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-748448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%20%3A%20Option%20permettant%20de%20faire%20fonctionner%20le%20filtre%20de%20donn%C3%A9es%20conditionnel%20de%20haut%20en%20bas%20au%20lieu%20de%20l'ordre%20de%20s%C3%A9lection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-748448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESalut%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F14366%22%20target%3D%22_blank%22%3E%40jthi%3C%2FA%3E%20-%20merci%20pour%20la%20suggestion.%20Concernant%20la%20d%C3%A9pendance%20%C3%A0%20l'ordre%20du%20comportement%20conditionnel%2C%20je%20tiens%20%C3%A0%20souligner%20qu'%C3%A0%20chaque%20fois%20que%20vous%20effacez%20le%20filtre%2C%20un%20nouvel%20ordre%20conditionnel%20peut%20%C3%AAtre%20utilis%C3%A9.%20Il%20est%20%C3%A9galement%20possible%20de%20r%C3%A9organiser%20les%20%C3%A9l%C3%A9ments%20de%20filtre%20%C3%A0%20votre%20guise%20par%20glisser-d%C3%A9poser.%20Actuellement%2C%20le%20glisser-d%C3%A9poser%20n%E2%80%99entra%C3%AEne%20pas%20de%20modification%20de%20l%E2%80%99ordre%20conditionnel.%20Avec%20l'option%20sugg%C3%A9r%C3%A9e%2C%20je%20pense%20que%20la%20r%C3%A9organisation%20des%20%C3%A9l%C3%A9ments%20de%20filtre%20affecterait%20%C3%A9galement%20l'ordre%20conditionnel.%20Est-ce%20ce%20%C3%A0%20quoi%20vous%20vous%20attendriez%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
Option to make Conditional Data Filter work from top to bottom instead of selection order
There are quite a few wish list items regarding data filters but quickly check I didn't find one exactly like this
Using highly useful conditional data filter and realizing that is is very order dependent.
Some option which would allow me to force the order of Conditional data filter be from top to bottom
Why is this idea important?
Gives more flexibility to conditional data filters and makes it more user-friendly (in my opinion).
2 Comments
danschikore
Hi @jthi - thanks for the suggestion.  On the order-dependence of the conditional behavior, I want to point out that each time you Clear the filter, a new conditional order can be used.  It is also possible to rearrange the filter items to your liking with drag-and-drop.  Currently, drag-and-drop does not result in a change in the conditional order.  With the suggested option, I think reordering the filter items would also affect the conditional order.  Is that what you would expect?
jthi
Yes, it is (though I wouldn't mind if I could prevent that when scripting BUT it could get very confusing to users)
