%3CLINGO-SUB%20id%3D%22lingo-sub-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAnalisi%20delle%20reti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EL'analisi%20fattoriale%20%C3%A8%20la%20pi%C3%B9%20importante%20per%20il%20controllo%20di%20qualit%C3%A0%20nell'industria%20manifatturiera.%20Pertanto%2C%20vengono%20utilizzati%20metodi%20di%20progettazione%20sperimentale%20e%20analisi%20multivariata%2C%20ma%20queste%20tecniche%20presuppongono%20un%20modello%20semplice.%20Tuttavia%2C%20non%20%C3%A8%20appropriato%20analizzare%20fenomeni%20complessi.%20SEM%20%C3%A8%20stato%20aggiunto%20a%20JMP16%20come%20metodo%20per%20analizzare%20fenomeni%20complessi.%20Tuttavia%2C%20il%20SEM%20%C3%A8%20molto%20complesso%20da%20utilizzare.%20Pertanto%2C%20ritengo%20che%20la%20difficolt%C3%A0%20sia%20elevata.%20Come%20preelaborazione%2C%20riteniamo%20che%20sia%20necessario%20un%20metodo%20in%20grado%20di%20analizzare%20i%20dati.%20Ad%20esempio%2C%20glasso%20%2C%20LiNGAM%2C%20Bayesian-Networks.%20Penso%20che%20queste%20tecniche%20siano%20utili%20anche%20per%20molte%20aziende.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EModellazione%20statistica%20avanzata%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ERicerche%20sui%20consumatori%20e%20sul%20mercato%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Networks analysis
Factor analysis is the most important for quality control in the manufacturing industry.Therefore, experimental design methods and multivariable analysis are used, but these techniques assume a simple model.However, it is not appropriate to analyze complex phenomena.SEM has been added to JMP16 as a method for analyzing complex phenomena.However, SEM is very complex to operate.Therefore, I feel that the difficulty is high.As a preprocessing, we believe that a method that can analyze the data as it is necessary.For example, glasso, LiNGAM, Bayesian-Networks.I think these techniques are also useful for many companies.
