%3CLINGO-SUB%20id%3D%22lingo-sub-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAn%C3%A1lisis%20de%20redes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EEl%20an%C3%A1lisis%20factorial%20es%20el%20m%C3%A1s%20importante%20para%20el%20control%20de%20calidad%20en%20la%20industria%20manufacturera.%20Por%20lo%20tanto%2C%20se%20utilizan%20m%C3%A9todos%20de%20dise%C3%B1o%20experimental%20y%20an%C3%A1lisis%20multivariable%2C%20pero%20estas%20t%C3%A9cnicas%20suponen%20un%20modelo%20simple.%20Sin%20embargo%2C%20no%20es%20apropiado%20analizar%20fen%C3%B3menos%20complejos.%20SEM%20se%20ha%20agregado%20a%20JMP16%20como%20m%C3%A9todo%20para%20analizar%20fen%C3%B3menos%20complejos.%20Sin%20embargo%2C%20SEM%20es%20muy%20complejo%20de%20operar.%20Por%20lo%20tanto%2C%20creo%20que%20la%20dificultad%20es%20alta.%20Como%20preprocesamiento%2C%20creemos%20que%20un%20m%C3%A9todo%20que%20pueda%20analizar%20los%20datos%20seg%C3%BAn%20sea%20necesario.%20Por%20ejemplo%2C%20glasso%20%2C%20LiNGAM%2C%20Bayesian-Networks.%20Creo%20que%20estas%20t%C3%A9cnicas%20tambi%C3%A9n%20son%20%C3%BAtiles%20para%20muchas%20empresas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EModelado%20estad%C3%ADstico%20avanzado%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInvestigaci%C3%B3n%20de%20Consumidores%20y%20Mercados%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Networks analysis
Factor analysis is the most important for quality control in the manufacturing industry.Therefore, experimental design methods and multivariable analysis are used, but these techniques assume a simple model.However, it is not appropriate to analyze complex phenomena.SEM has been added to JMP16 as a method for analyzing complex phenomena.However, SEM is very complex to operate.Therefore, I feel that the difficulty is high.As a preprocessing, we believe that a method that can analyze the data as it is necessary.For example, glasso, LiNGAM, Bayesian-Networks.I think these techniques are also useful for many companies.
