%3CLINGO-SUB%20id%3D%22lingo-sub-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ENetzwerkanalyse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EDie%20Faktorenanalyse%20ist%20f%C3%BCr%20die%20Qualit%C3%A4tskontrolle%20in%20der%20Fertigungsindustrie%20am%20wichtigsten.%20Daher%20werden%20experimentelle%20Entwurfsmethoden%20und%20multivariable%20Analysen%20verwendet%2C%20aber%20diese%20Techniken%20gehen%20von%20einem%20einfachen%20Modell%20aus.%20Sie%20ist%20jedoch%20nicht%20f%C3%BCr%20die%20Analyse%20komplexer%20Ph%C3%A4nomene%20geeignet.%20SEM%20wurde%20zu%20JMP16%20hinzugef%C3%BCgt%20als%20Methode%20zur%20Analyse%20komplexer%20Ph%C3%A4nomene.%20SEM%20ist%20jedoch%20sehr%20komplex%20in%20der%20Bedienung.%20Daher%20halte%20ich%20die%20Schwierigkeit%20f%C3%BCr%20hoch.%20Als%20Vorverarbeitung%20glauben%20wir%2C%20dass%20eine%20Methode%20die%20Daten%20nach%20Bedarf%20analysieren%20kann.%20Zum%20Beispiel%20Glasso%20%2C%20LiNGAM%2C%20Bayesian-Networks.%20Ich%20denke%2C%20diese%20Techniken%20sind%20auch%20f%C3%BCr%20viele%20Unternehmen%20n%C3%BCtzlich.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-447938%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EErweiterte%20statistische%20Modellierung%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EVerbraucher-%20und%20Marktforschung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Networks analysis
Factor analysis is the most important for quality control in the manufacturing industry.Therefore, experimental design methods and multivariable analysis are used, but these techniques assume a simple model.However, it is not appropriate to analyze complex phenomena.SEM has been added to JMP16 as a method for analyzing complex phenomena.However, SEM is very complex to operate.Therefore, I feel that the difficulty is high.As a preprocessing, we believe that a method that can analyze the data as it is necessary.For example, glasso, LiNGAM, Bayesian-Networks.I think these techniques are also useful for many companies.
