Local Data Filter: option use the selection as graph title
A graph can be misleading if a data filter is applied - the graph doesn't show the whole data set but just a selection.
Special use case:
a user wants to generate 5 different plots for different subsets.
At the moment, it's hard to track: which plot belongs to which setting?
To highlight the individual selections, a footer can be activated which shows the selection of the data filter:
The disadvantage: For complicated filter settings the string can get VERY long -
and I agree with @Neo: sometimes it's just a single part of the data filter which should be highlighted in the plot - e.g. as graph title:
Is it possible to dynamically update "graph title" based item selection in local data filter (includ...
At the moment, the user has to apply some JSL magic to get the desired result:
In the read triangle menu of a local data filter, please add the option use as graph title.
If the new option is selected for one or more data filter, Jmp collect the information about the selected entries and display it as graph title.
Why is this idea important?
low hanging fruit that will make many Jmp users happy:
Putting part of the data filter information into the graph title is an easy way to make graphs more meaningful.
3 Comments
hogi
Level XIII
Actually, slightly (*) enhance the feature of Tabulate and use it as well for Graph Builder:
(*) Tabulate already shows the selection as the Title - if there is a single data filter.
Names Default to Here(1);
dt << Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Statistics( Mean ), Analysis Columns( :height ) ),
		Row Table( Grouping Columns( :age ) )
	Local Data Filter(
		Conditional,
		Mode( Show( 0 ) ),
		Add Filter(
			columns( :age ),
			Where( :age == {14, 15} ),
			Display( :age, N Items( 6 ) )
hogi
Level XIII
@Sarah-Sylvestre : can be marked as duplicate of Auto population of title - graph builder
Sarah-Sylvestre
Level V
Status changed to: Duplicate
