%3CLINGO-SUB%20id%3D%22lingo-sub-579405%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJSL-Option%20zum%20Zur%C3%BCckgeben%20der%20Mausposition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-579405%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20w%C3%BCrde%20gerne%20eine%20JSL-Codeoption%20sehen%2C%20die%20die%20Koordinaten%20der%20Maus%20zur%C3%BCckgibt%2C%20damit%20ein%20neues%20Fenster%20in%20Bezug%20auf%20die%20Mausposition%20positioniert%20werden%20kann.Dadurch%20kann%20das%20neue%20Fenster%20in%20der%20N%C3%A4he%20der%20Maus%20platziert%20werden%2C%20sodass%20Sie%20schnell%20auf%20die%20Optionen%20im%20Fenster%20zugreifen%20k%C3%B6nnen.Ich%20verwende%20dies%20so%2C%20dass%20ein%20neues%20Fenster%20generiert%20wird%2C%20das%20Skriptschaltfl%C3%A4chen%20f%C3%BCr%20h%C3%A4ufig%20verwendete%20Aktionen%20enth%C3%A4lt.%20Wenn%20es%20also%20in%20der%20N%C3%A4he%20der%20Maus%20erscheint%2C%20wird%20die%20Effizienz%20gesteigert%2C%20anstatt%20die%20Maus%20nach%20oben%20zur%20Symbolleiste%20bewegen%20zu%20m%C3%BCssen%20(je%20gr%C3%B6%C3%9Fer%20der%20Bildschirm).%20mehr%2C%20das%20kann%20von%20Bedeutung%20sein!).%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EVielen%20Dank%2C%20dass%20Sie%20diese%20Anfrage%20ber%C3%BCcksichtigt%20haben.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-579405%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAutomatisierung%20und%20Skripterstellung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-580512%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20JSL-Option%20zur%20R%C3%BCckgabe%20der%20Mausposition%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Best%C3%A4tigt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-580512%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F16391%22%20target%3D%22_blank%22%3E%20%40shampton82%3C%2FA%3E%20%2C%20Danke%20f%C3%BCr%20deinen%20Vorschlag!%20Wir%20haben%20Ihre%20Anfrage%20erfasst%20und%20werden%20diese%20pr%C3%BCfen.%3C%2FP%3E%3C%2FLINGO-BODY%3E
JSL option to return mouse location
I'd like to see a JSL code option that would return the coordinates of the mouse so that a new window can be position in reference to the mouse location.  This will allow the new window to be located close to the mouse for quick access of options on the window.  How I will be using this is  a new window will be generated that contains scripting buttons for often used actions and thus having it appear near the mouse will allow an efficiency gain vs having to move the mouse up to the toolbar (the bigger the screen the more this can matter!).
Thanks for considering this request.
Steve
2 Comments
Hi @shampton82, thank you for your suggestion! We have captured your request and will take it under consideration.
