%3CLINGO-SUB%20id%3D%22lingo-sub-682434%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJMP-Auswahlform%20%E2%80%93%20Sie%20m%C3%B6chten%20einen%20Kreis%2Fein%20Oval%20anstelle%20eines%20Rechtecks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-682434%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20diese%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EWenn%20ich%20derzeit%20versuche%2C%20einige%20Stichproben%20aus%20einer%20grafischen%20Darstellung%20auszuw%C3%A4hlen%2C%20kann%20die%20Auswahl%20nur%20durch%20Zeichnen%20eines%20Rechtecks%20erfolgen.Allerdings%20muss%20ich%20h%C3%A4ufig%20Proben%20anhand%20einer%20kreisf%C3%B6rmigen%20oder%20ovalen%20Form%20ausw%C3%A4hlen.%20Mit%20der%20aktuellen%20Methode%20ist%20es%20sehr%20schwierig%2C%20jede%20einzelne%20Probe%20herauszupicken.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20sich%20w%C3%BCnschen%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EF%C3%BCgen%20Sie%20eine%20Form%20f%C3%BCr%20den%20Auswahlpfeil%20hinzu%2C%20damit%20wir%20ausw%C3%A4hlen%20k%C3%B6nnen%2C%20ob%20wir%20Proben%20durch%20Zeichnen%20eines%20Kreises%20oder%20eines%20Rechtecks%20ausw%C3%A4hlen%20m%C3%B6chten.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EViele%20Unternehmen%2C%20die%20an%20wafer%C3%A4hnlichen%20Produkten%20arbeiten%2C%20haben%20nat%C3%BCrlich%20eine%20Kreisform.In%20diesem%20Fall%20gibt%20es%20h%C3%A4ufig%20kreisf%C3%B6rmige%20oder%20ovale%20Formfehler%20und%20Gleichm%C3%A4%C3%9Figkeitsprobleme%2C%20die%20ausgew%C3%A4hlt%20werden%20m%C3%BCssen.Die%20Benutzergruppe%20ist%20riesig%2C%20da%20die%20meisten%20Unternehmen%20oder%20Hersteller%20von%20Halbleiter-%20oder%20anderen%20Kreislaufprodukten%20ein%20solches%20Tool%20zur%20Unterst%C3%BCtzung%20ben%C3%B6tigen.Eine%20solche%20Auswahlform%20spart%20viel%20Zeit.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-682434%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGrundlegende%20Datenanalyse%20und%20Modellierung%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDatenexploration%20und%20-visualisierung%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EQualit%C3%A4ts-%20und%20Verfahrenstechnik%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EZuverl%C3%A4ssigkeitsanalyse%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EErgebnisse%20teilen%20und%20kommunizieren%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-682722%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20JMP-Auswahlform%20%E2%80%93%20Sie%20m%C3%B6chten%20einen%20Kreis%2Fein%20Oval%20anstelle%20eines%20Rechtecks%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-682722%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELasso%20ist%20sehr%20hilfreich%2C%20um%20nicht%20rechteckige%20Muster%20auszuw%C3%A4hlen.%3C%2FP%3E%3C%2FLINGO-BODY%3E
JMP selection shape - Want a circle/oval instead of rectangle
Currently, when I trying to chose some samples from a plot of graph, it can only select by drawing a rectangular.  However, a lot of times, I need to select samples by a circular or oval shape, it's very hard to cherry pick each sample by using current method.
Add a shape chose for select arrow, so we can chose if we want to select samples by drawing a circle or rectangular.
Why is this idea important?
Many company working on wafer like products, it's naturally a circle shape.  In this case, a lot of times, there are circular or oval shape defects, uniformity issue that need to be selected.  The user group is huge, since most semiconductor or other circular products company or manufacture need such tool to help.  It will be greatly saving time to have such selection shape.
1 Comment
hogi
Level XII
Lasso ist very helpful to select non-rectangular patterns.
