%3CLINGO-SUB%20id%3D%22lingo-sub-425840%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EJMP%20Clinical%20-%20Opzioni%20di%20risposta%20al%20tumore%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-425840%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ENella%20creazione%20dei%20report%20clinici%20JMP%2C%20attualmente%20per%20Oncologia%3A%20risposta%20tumorale%2C%20le%20uniche%20variabili%20da%20visualizzare%20sono%20LDIAM%20e%20LPERP.%20Queste%20opzioni%20non%20ci%20consentono%20di%20tenere%20conto%20di%20pi%C3%B9%20tumori%2Flesioni%2C%20come%20delineato%20nelle%20linee%20guida%20RECIST%20(%20%3CA%20href%3D%22https%3A%2F%2Fctep.cancer.gov%2FprotocolDevelopment%2Fdocs%2FRecist_Guideline.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fctep.cancer.gov%2FprotocolDevelopment%2Fdocs%2FRecist_Guideline.pdf%3C%2FA%3E%20).%20Sarebbe%20utile%20se%20pi%C3%B9%20opzioni%20(SUMPPD%2C%20PROD%20PPD%2C%20ecc.)%20fossero%20incluse%20come%20opzioni%20per%20il%20test%20dei%20risultati%20del%20tumore%20per%20l'analisi%20per%20visualizzare%20accuratamente%20queste%20informazioni%20per%20i%20tumori%20che%20coinvolgono%20pi%C3%B9%20tumori.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EAllo%20stesso%20modo%2C%20per%20i%20tumori%20con%20tumori%20multipli%2C%20sarebbe%20utile%20se%20ci%20fosse%20un%20modo%20per%20indicare%20quale%20tumore%20%C3%A8%20rappresentato%20nella%20figura%2C%20nonch%C3%A9%20per%20esaminare%20potenzialmente%20pi%C3%B9%20tumori%2Flesioni%20o%20selezionare%20tumori%2Flesioni%20specifici%20da%20esaminare.%20Ci%C3%B2%20potrebbe%20applicarsi%20sia%20al%20rapporto%20Oncologia%20-%20Risposta%20tumorale%20che%20ai%20grafici%20a%20cascata%20dei%20risultati%20tumorali.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EGrazie%2C%3C%2FP%3E%3CP%3ESamantha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-425840%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JMP Clinical - Tumor Response Options
In making JMP Clinical Reports, currently for Oncology: Tumor Response, the only variables to display are LDIAM and LPERP. These options don't allow us to account for multiple tumors/lesions, as outlined in the RECIST guidelines (https://ctep.cancer.gov/protocolDevelopment/docs/Recist_Guideline.pdf). It would be helpful if more options (SUMPPD, PROD PPD, etc.) were included as options for Tumor Results Test for Analysis to accurately display this information for cancers involving multiple tumors.
Similarly, for cancers with multiple tumors, it would be helpful if there was a way to indicate which tumor is being represented in the figure, as well as to potentially look at multiple tumors/lesions, or select specific tumors/lesions to look at. This could apply for both the Oncology - Tumor Response Report as well as Tumor Results Waterfall Plots.
Thanks,
Samantha
1 Comment
Jun
Agree, Some China JMPC customers also ask the same questions, like InnoCare
