%3CLINGO-SUB%20id%3D%22lingo-sub-49864%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EOpzione%20Colonna%20indicatore%20in%20Esplora%20valori%20anomali%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-49864%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAnalizza%20%26gt%3B%20Screening%20%26gt%3B%20Esplora%20valori%20anomali%3A%20vorrei%20avere%20un'opzione%20per%20restituire%20i%20risultati%20come%20colonna%20indicatrice%20((0%7C1)%2C%20dove%201%20indica%20un%20valore%20anomalo.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAttualmente%2C%20le%20opzioni%20di%20risultato%20sono%3A%20Seleziona%20righe%2C%20Colora%20celle%2C%20Escludi%20righe%2C%20Colora%20righe%2C%20Aggiungi%20a%20codici%20valore%20mancanti%2C%20Cambia%20in%20mancante.%20Naturalmente%2C%20%C3%A8%20piuttosto%20facile%20duplicare%20la%20colonna%20dati%2C%20Cambia%20in%20mancante%20e%20poi%20tramite%20script%20o%20formula%20trasformarla%20in%20una%20colonna%20indicatore.%20Ma%20sarebbe%20bello%20avere%20Crea%20colonna%20indicatore%20come%20opzione%20nativa.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-49864%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EFusione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Indicator Column option in Explore Outliers
Analyze > Screening > Explore Outliers, would like an option to output the results as an indicator column ((0|1), where 1 indicates outlier.
Currently, the result options are: Select Rows, Color Cells, Exclude Rows, Color Rows, Add to Missing Value Codes, Change to Missing. Of course, it is pretty easy to just duplicate the data column, Change to Missing, and then by script or formula turn that into an indicator column. But it would be nice to have Make Indicator Column as a native option.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
