%3CLINGO-SUB%20id%3D%22lingo-sub-243461%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMiglioramenti%20alla%20finestra%20di%20scripting%20per%20gli%20script%20incorporati%20in%20una%20tabella%20dati%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-243461%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EQuando%20si%20scrive%20uno%20script%20incorporato%20in%20una%20tabella%20di%20dati%2C%20esistono%20diversi%20problemi%20rispetto%20a%20un%20file%20di%20script%20autonomo.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ENon%20%C3%A8%20presente%20alcun%20registro%20incorporato.%20Se%20voglio%20vedere%20cosa%20c'%C3%A8%20nel%20registro%2C%20devo%20passare%20attraverso%20il%20debugger.%20Ma%20non%20mi%20piace%20questa%20opzione%20poich%C3%A9%20il%20debugger%20ha%20una%20forte%20tendenza%20a%20mandare%20in%20crash%20JMP.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EPossiamo%20avere%20un%20registro%20incorporato%20nelle%20finestre%20degli%20script%20dipendenti%20dalla%20tabella%20dati%3F%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EAl%20momento%20dell'esecuzione%2C%20la%20tabella%20dati%20non%20viene%20salvata%20automaticamente.%20Ci%C3%B2%20significa%20che%20quando%20eseguo%20uno%20script%20e%20JMP%20si%20blocca%20(non%20so%20se%20%C3%A8%20solo%20colpa%20mia%2C%20ma%20succede%20MOLTO)%2C%20il%20mio%20lavoro%20va%20perso%20se%20non%20salvo%20la%20tabella%20dei%20dati.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EPossiamo%20avere%20un'opzione%20di%20salvataggio%20automatico%3F%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-243461%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EOrganizzazione%20dei%20contenuti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECondivisione%20e%20comunicazione%20dei%20risultati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Improvements for scripting window for scripts embedded in a data table
When you are writing a script embedded in a data table, there are several issues compared to a stand alone script file.
  • There is no Embedded log. If I want t o see what is in the log, I have to go through the debugger. But I don't like this option as the debugger has a strong tendency to crash JMP.
Can we please have an embedded log in the datatable-dependent script windows ?
  • Upon execution, the data table is not saved automatically. This means that when I run a script and JMP crashes (I don't know if it is just me but that happens A LOT), my work is lost if I didn't save the data table.
Can we have an autosave option ?
