%3CLINGO-SUB%20id%3D%22lingo-sub-782698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIntroducci%C3%B3n%20y%20edici%C3%B3n%20de%20texto%20de%20diario%20mejorada%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-782698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EHe%20estado%20usando%20m%C3%A1s%20las%20revistas%20como%20documentaci%C3%B3n%20para%20el%20an%C3%A1lisis%20de%20mis%20estudios.%20Esto%20requiere%20bastante%20texto%2C%20a%20menudo%20mucho%20m%C3%A1s%20del%20que%20veo%20que%20utilizan%20muchas%20revistas%20de%20ejemplo.%20Lamentablemente%2C%20la%20edici%C3%B3n%20actual%20de%20revistas%20es%20bastante%20torpe%20para%20grandes%20vol%C3%BAmenes%20de%20texto.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EMejoras%20en%20la%20edici%C3%B3n%20de%20textos%20del%20diario.%20Algunas%20que%20personalmente%20creo%20que%20ser%C3%ADan%20%C3%BAtiles%20son%3A%3C%2FP%3E%3CUL%3E%3CLI%3ENegrita%2C%20cursiva%2C%20subrayado%20y%20sub%C3%ADndices%2Fsuper%C3%ADndices%3C%2FLI%3E%3CLI%3ELa%20capacidad%20de%20tener%20m%C3%BAltiples%20vi%C3%B1etas%20dentro%20de%20un%20cuadro%20de%20texto%2C%20en%20lugar%20de%20que%20cada%20vi%C3%B1eta%20requiera%20un%20posicionamiento%20individual.%3C%2FLI%3E%3CLI%3EUn%20formato%20de%20cuadro%20de%20texto%20para%20funciones%20de%20lista%20(1%2C%202%2C%203%2C%20etc.)%3C%2FLI%3E%3CLI%3EIncluir%20formato%20para%20vi%C3%B1etas%20secundarias%3C%2FLI%3E%3CLI%3EIncluye%20opciones%20de%20formato%20para%20m%C3%BAltiples%20tipos%20de%20vi%C3%B1etas%20(n%C3%BAmeros%2C%20n%C3%BAmeros%20romanos%2C%20cuadrados%2C%20huecos%2C%20etc.)%3C%2FLI%3E%3CLI%3EAgregar%20un%20elemento%20de%20texto%20debajo%20de%20un%20encabezado%20de%20esquema%20solo%20agrega%20el%20cuadro%20al%20diario%20en%20lugar%20de%20la%20pantalla%20emergente%2C%20lo%20que%20hace%20que%20agregar%20texto%20largo%20o%20m%C3%BAltiples%20vi%C3%B1etas%20sea%20frustrante.%3C%2FLI%3E%3CLI%3ECapacidad%20de%20tener%20sangr%C3%ADas%20de%20p%C3%A1rrafos%20y%20vi%C3%B1etas%20sangradas%20dentro%20de%20cuadros%20de%20texto%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ELa%20capacidad%20de%20guardar%20documentaci%C3%B3n%2C%20notas%2C%20instrucciones%20y%20m%C3%A1s%20dentro%20del%20software%20es%20una%20caracter%C3%ADstica%20excelente%20que%20mejora%20el%20flujo%20de%20trabajo%20y%20la%20reproducibilidad.%20Los%20diarios%20tambi%C3%A9n%20tienen%20excelentes%20formas%20de%20incorporar%20scripts%2C%20archivos%20e%20im%C3%A1genes%20JMP%20con%20mucha%20facilidad%2C%20lo%20que%20los%20hace%20preferibles%20a%20mantener%20la%20documentaci%C3%B3n%20en%20un%20procesador%20de%20texto%20externo.%20La%20edici%C3%B3n%20de%20texto%20dentro%20del%20diario%20no%20est%C3%A1%20tan%20bien%20desarrollada%20y%20es%20especialmente%20limitante%20para%20textos%20de%20formato%20m%C3%A1s%20largo.%20Esto%20limita%20mi%20capacidad%2C%20y%20probablemente%20la%20de%20otros%20usuarios%2C%20de%20utilizar%20por%20completo%20la%20plataforma%20del%20diario.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-782698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ECompartir%20y%20comunicar%20resultados%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-797478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Mejoras%20en%20la%20edici%C3%B3n%20y%20entrada%20de%20texto%20en%20el%20diario%3A%20el%20estado%20ha%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-797478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGracias%20por%20estas%20sugerencias.%20Se%20est%C3%A1%20trabajando%20para%20%3CSPAN%20data-teams%3D%22true%22%3E%3CSPAN%20class%3D%22ui-provider%20a%20b%20c%20d%20e%20f%20g%20h%20i%20j%20k%20l%20m%20n%20o%20p%20q%20r%20s%20t%20u%20v%20w%20x%20y%20z%20ab%20ac%20ae%20af%20ag%20ah%20ai%20aj%20ak%22%3Eagregar%20compatibilidad%20con%20algunas%20de%20estas%20solicitudes%20en%20el%20marcado%20de%20cuadro%20de%20texto%20existente%20en%20Journals.%20Adem%C3%A1s%2C%20estamos%20trabajando%20para%20agregar%20una%20nueva%20funci%C3%B3n%2C%20JMP%20Notebook%2C%20que%20ayudar%C3%A1%20a%20abordar%20las%20necesidades%20de%20documentaci%C3%B3n.%20Si%20es%20un%20usuario%20autorizado%20(JMP%2018)%20y%20desea%20echar%20un%20vistazo%20a%20lo%20que%20estamos%20haciendo%20y%20brindar%20comentarios%2C%20puede%20unirse%20al%20programa%20JMP%20Early%20Adopter%20en%20jmp.com%2Fearlyadopter.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
Improved Journal Text Input and Editing
I have been using journals more as documentation for my study analysis. This requires quite a bit of text, often much more than I see many example journals utilizing. Unfortunately, the current journal editing is quite clunky for large bodies of text.
Improvements for the journal text editing. Some I personally would think are helpful are:
  • Bolding, italicizing, underline, and sub/super scripts
  • The ability to have multiple bullet points within one text box, instead of each bullet point requiring individual positioning.
  • A text box format for list functions ( 1. 2. 3. etc)
  • Including formatting for sub-bullet points
  • Including formatting options for multiple kinds of bullet points (numbers, roman numerals, squares, hollow, ect.)
  • Adding a text item below a outline heading just adds the box into the journal rather than the pop up screen which makes adding long text or multiple bullet points frustrating
  • Ability to have paragraph indents and indented bullet points within text boxes
Why is this idea important?
The ability to save documentation, notes, instructions, and more within the software is a great feature that improves workflow and reproducibility.  The Journals also have great ways to incorporate JMP scripts, files, and images very easily, which makes them preferable to keeping documentation in an outside word processor. The text editing within the journal is not as well developed and is especially limiting for longer-form text. This limits my ability, and likely other users, to fully utilize the journal platform.
1 Comment
mia_stephens
Thank you for these suggestions. There's some work underway to add support for some of these requests into the existing text box markup in Journals. And, we're working on adding a new feature, JMP Notebook, which will help address the documentation needs. If you are an authorized user (JMP 18) and would like to take a look at what we're working on and give feedback, you can join the JMP Early Adopter program at jmp.com/earlyadopter.
